NorStar Startalk Flash 2 Phone Logo
EveL Posted on Sep 03, 2013
Remove do not disturb - NorStar Startalk Flash 2 Phone
Rich Barnett
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Oct 24, 2013
Rich Barnett
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
3236
Points
19
You need to enter the "Make Set Busy Deactivate Flexible Feature Code" - the "Flexible" part meaning the system administrator can change it, so you'll have to ask. The default appears to be #62.
2answers
Iphone 5 won't alert me to texts or calls
go to settings-> do not disturb and make sure do not disturb is off, you can also check to see if do not disturb is on by seeing if there is a moon in your status bar
Do not disturb
If you do not have the owner's manual, try removing it from the phone line and remove any batteries that it might have too. Completely removing any electrical source usually resets most electronics to its out of the box mode.
1helpful
SX-50 Mitel wake up calls won't go through to rooms. Is there a way to reset or fix this?
Your Wake up device is in DND.... it either didn't hang up or it didn't answer. You should contact your vendor to have them check the RAD (Recorded Announcement Device).
Unless you know the extension number associated with it (the installers use different numbering from site to site and I couldn't even guess for you), you won't be able to clear the DND. If you do know the ext number... follow these instructions from the attendant console.
To apply Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number.
• Press the DND ON softkey.
• If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension.
• Press the EXIT softkey.
To remove Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB.
• Press the DND OFF softkey.
How do i remove dnd on a samsung dcs 408 pabx ?
The short code to disable Do Not Disturb is 400, 401 sets the Do Not Disturb. I have sent you a video explaining Do Not Disturb on a Samsung DCS, there are other useful tips on youtube if you search for abbeytel. Please visit www.abbeytelecom.com for written introduction, thank you
2helpful
Mitel sx 50.. How to unlock room phone..how to take it off from do not distrub(in room phone)? Thank you so much
Attendant
94helpful
How to disable do not disturb from Nortel phone
FEATURE 85 sets "Do Not Disturb", and to cancel any feature, add a # sign.
FEATURE # 85 will cancel it. :)
How can i remove the "do not disturb' features in my phone Nortel T7208
hey i have the solution. push the function button, then pound, then 85. hopes this helps. i had the same problem and i worked for me
3answers
Troubleshooting GE 25952 5.8 GHz Twin Cordless
Just press the same button again and the light will go off removing DnD option
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
