Question about Nokia 3595
0/spacebar button does not work. all others do work. have opened phone, checked, and the spot under the button only works occasionally when pushed in 1 tiny spot with pointed object ... suggestions?
    New Friend:
  • 6 Answers
Molds or carbon may have accumulated in between the copper sides of the 0/ spacebar button.
Posted on Sep 03, 2013
  • carol yeager Sep 04, 2013
    Thank you. Will see what I can do to check it out.
6ya staff
SOURCE:
Spacebar somewhat jammed
There may be something stuck under the bar like a crumb of biscuit or a bit of grit that stops the bar from free movement.
Feb 07, 2014 | ASUS Computers & Internet
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
My spacebar is not working. How can I fix it?
You should contact the manufacturer it is already hardware issue.
If your unit is under warranty then they will replace the entire keyboard free.
May 13, 2010 | Fujitsu LifeBook T4210 Tablet PC
Laptop key popped out!
Have you tried pushing the key back on the blank spot hard? Usually it will clip itself back on.
Mar 11, 2010 | Acer Aspire One PC Notebook
Problemwith spacebar
If you take all those tiny screws out of the bottom of the keyboard you'll see a circuitboard with three copper "design" spots(usually 3) under the spacebar..........the ones NOT in the center of the spacebar are dirty. You could use some alcohol or acetone to clean the outside "designs".....(warning) Acetone will damage plastic!!!!!!!!
there are a lot of rubber caps that WILL fall out of place when you turn it over) (the actual keys could fall out too) (Be careful when you take off the bottom of the keyboard!!!!) Clean the ones that align with the SPACEBAR!!!! Dont touch or clean anything else that wasn't working....... Gently place the bottom back on and screw down the bottom cover with a cross pattern.....(left>right...top>bottom).....If this dosn't work....the best part is that a new keyboard........is fairly cheap....mtg
Apr 14, 2009 | Computers & Internet
Sidekick lx spacebar
Go to:
http://www.fixmysidekick.com/sidekick-lx-or-sidekick-2008-space-bar-not-working/164/
Or just read this...:
sidekick2008spacebarpicture.jpgIs the space bar on your Sidekick LX not working when you are trying to text or in AIM? Do you have thesame space bar button problem on your T-mobile Sidekick 2008? Does the Sidekick spacebar work in other apps though?
If so then this fix is for you.
1. Open the AutoText & Spelling screen. From the Jump screen, press the MENU button, then select Settings > AutoText & Spelling.
2. Uncheck the following settings:
    • Highlight misspelled words
    • Auto correct spelling
3. Exit out of the settings screen and try it out.
Hopefully, this will have solved your issue.
How to check for misspelled words with these two options unchecked?
Run a manual spell check on T-mobile Sidekick: To run a spell check while in a text field from any Edit Text submenu, or by using the keyboard shortcut by pressing MENU +S.
Dec 19, 2008 | Sharp Sidekick LX Smartphone
Mx3200 First the spacebar won't work andthenitworkstoowell.
did you check to make sure that the springs and bar under the spacebar are seated correclty?
Sep 30, 2008 | Logitech 967437-0403 Keyboard
Spacebar on keyboard not working
turn the keyboard over and tap the bottom. You may have a piece of fodder under it.
Jan 04, 2008 | Dell Inspiron 2650 Notebook
Frozen pad buttons
I have the same problem but it's 1, 4 7. I squeezed the edges of the keypad and it seems to have aligned things up again.
Nov 01, 2007 | LG Chocolate Clamshell VX8600 Cellular...
Nokia 3595 Logo
49 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
