Televison & Video Logo
Question about Toshiba Televison & Video
I have uet-606 universal remote control, but i don't have the manual book, if you can send me one on line or the code no. for sony TV
Posted by Ssali Isaac on
wizkid18
  • 125 Answers
Buy another one on Ebay universal remote control5.00 dollars from china
Posted on Oct 25, 2013
5 Related Answers
Anonymous
SOURCE: Can you Help me with One For All UET -606 Remote
i have broksonic and am using uet-606 universal remote control and i do not see any codes for it please help me
Posted on Nov 23, 2011
gopakumarg43
  • 76851 Answers
SOURCE: can you help me with the setup codes for uet-606 AV12 universal remote control for sony and samsung tvs. i can't seem to find where the manual is. Thank you.
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Pull up older posts there. Setup codes for almost all TVs are given. You can see the proceedings too. Sometimes, click open, adverts' by the side and bottom of each post might give your more details.
Posted on May 27, 2012
gopakumarg43
  • 76851 Answers
SOURCE: uet-606 universal remote control code for comet tv
Just do a code search method. It will be best rather than try to get the code list to this remote control. If your remote control have pre-programmed codes for your device, this method will help you to synchronize it, and you can retrieve the code too. Procedingns are given.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Posted on Jun 24, 2012
Anonymous
SOURCE: I can not start using my universal remote control UET-606
i need to Aftron tv code
Posted on Oct 09, 2012
gopakumarg43
  • 76851 Answers
SOURCE: I con not find codes for my universal remote control UET-606
073,082,088,091,063 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Posted on Apr 06, 2013
Can you help me with one for all uet. 606 remote for grundig TV
Sounds familiar? A One For All universal remote control conveniently connects up to eight devices in your house at once. Uniquely this one handheld remote replaces the remotes for your TV, Blu-ray, streaming devices like Apple TV, soundbar, DVD, game consoles and media center.
https://www.oneforall.com/universal-remotes#/
How to configure UET-606 Universal remote for AEG TV
If you wish to get more; check the sites linked here. Both the sites have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
1helpful
What is the code to activate uet 606 av12 remote for SEG television?
Codes to check with SEG brand TVs are given below. If you wish to get more codes to different other remote controls, check these links.
0031 0062 0049 0051 0105 0004 0009 0107 0109 0110 0189 0000 0112 0079 0394 0456 0012 0015 0180
An you Help me for the CODE for All-in One universal remote Control brand "UET - 606 (AV12)?." I have PANDA TV
Check these setup codes. If you wish to get more codes to many other remote brands, check this link.
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
4helpful
2answers
5helpful
4answers
How to configure UET-606 Universal remote for NIKAI LCD TV?
Get the UET-606 Remote
1. Make sure its switched on
2. Point the UET-606 Remote towards the TV
3. Press the SET + TV button at the same time - the Red LED on Power will Illuminated solid Red
4. Press the SET Button again while still holding the TV button
5. the Power LED will begin to blink red
6 Enter the code 136
7. Press the Red Power button several times [sometimes 60 times] until the TV set resets itself
8. if the TV resets itself - point the remote away from the TV set and press any button or the SET button until the Power LED stops blinking
9. you are now ready to go
5helpful
1helpful
2answers
6helpful
2answers
Are you sure this is an AKARI TV? perhaps an AKAI model? I am not familiar with AKARI, and neither is www.google.com
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
