Question about Shure Audio Players & Recorders
Shure pg4/pg58 wireless handheld mic system goes in and out
It's nearly impossible to troubleshoot dropouts in a forum. Shure has some great troubleshooting hints at: www.shure.com/faq. Beyond that, call Shure at 800-516-2525 and they can help you troubleshoot over the phone.
Posted on Nov 25, 2013
SOURCE: shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Posted on Sep 28, 2009
SOURCE: Does the battery on my Shure PG58 Mic drain even
It depends on the quality of the battery.
My advice is to pull out the battery after a week of non using.
Regards,
Gerard
Posted on Jan 21, 2010
SOURCE: where can I by replacement parts for my shure
See delta Audio Chicago IL.
773-764-3634. Services all Shure
VHF Wireless systems since 1997.
factory trained tech.
Posted on Oct 21, 2010
SOURCE: Is the frequency used by
It depends on the specific frequency that you have. Some of the UT systems operated between 698 and 806 MHz, and they are now illegal.
Other UT systems operated below 698 MHz and those are still legal to use.
Look at the frequency that is on the sticker on the back or bottom of the receiver or the sticker that is in the battery compartment of the microphone.
Posted on Dec 26, 2010
SOURCE: We are using a Shure
Unfortunately, there are many, many things that can cause a unit to be non-functional. Try calling Shure to get it repaired, or call Delta Audio at 773-764-3634. Delta Audio also repairs older Shure equipment.
Posted on Jan 19, 2011
