Question about Tablets & eReaders
Proline tablet hard reset or pattern bypassing
Pontsho Mokoena
    New Friend:
It shows green screen only
Posted on Jan 12, 2017
  • Docile Felix
    Docile Felix Apr 24, 2017
    it just stays on a green screen. what do i do now?
  • Docile Felix
    still stays on green screen.what do i do now?
1 Related Answer
Anonymous
SOURCE: I need to reset my tablet to set a new pattern to
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Posted on Nov 02, 2013
tip
Android Tablet Hard Reset Method
If you had forgotten your Pattern lock of your Tablet, you can reset it of your own.
You can recover it through your Gmail account, enter the pattern for 15-20 times. After it you will be asked to enter your Gmail password.
But, if you do not remember Gmail password
then Hard reset will be the Final solution to your question.
Different Hard reset factory wipe methods for Android Tablet Different Hard reset factory wipe methods for Android Tablet
How to bypass pattern lock screen Polaroid pmid705
You will after hard reset the phone as there no way off passing the lock screen ps you will lose everything on your phone if you hard reset it
1helpful
2answers
Forgot pattern password
hard reset by recovery options
How do I bypass a pattern lock
Just reset the tablet
Search for reset instructions for your tablet
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
