Question about Texas Instruments TI-84 Plus Calculator
Scrolling sideways I'm solving a matrix. I put it in rref, but the answer column is off the screen to the right, and I can't figure out how to scroll over to it.
Posted by Solvei on
k24674
  • Texas Instru... Master
  • 8,091 Answers
Usually the right arrow allows you to move cursor to the right.
Posted on Sep 27, 2013
1 Related Answer
k24674
  • 8091 Answers
SOURCE: rref for 4X4 matrix does not answer correctly
To make sure that the calculator is misbehaving, I suggest that you create a simple 4X4 matrix, that is not singular, and calculate it reduced row echelon form by hand, then use the calculator to perform the reduction. You can also generate a random 4x4 matrix and calculate the rref forms by hand and with the calculator. If the calculator is defective, try to upgrade the OS. If it is still defective, well, the deck is stacked aaginst you. It may then be time to get another one or to send it for repairs.
Posted on Jan 21, 2012
CALL/ANSWER INFO ?
press on the green telephone icon and slide it sideways
just like you are scrolling the screen
Dec 17, 2016 | Cell Phones
When i troubleshoot my computer it says "there is a problem with the driver for Teredo Tunneling Pseudo-Interface. Reinstalling the driver might fix this problem." then it tries to reinstall this driver...
what you need to do is open up your device manager, you then need to click the action tab at the top and click add legacy hardwareicon1.png
then click next and next again it will then scan and find nothing click next on the screen after that.
Wait a minute and you will see a list of hardware appear, scroll down and choose network adapters then click next, then from the left column choose Microsofticon1.png then in the right hand column scroll down and choose Microsoft Teredo Tunneling Adapter, then click next and this will install it.
To check just make sure it is set to show hidden devices, right click on device manager on the right and click view then show hidden devices
May 14, 2014 | Computers & Internet
Rref for 4X4 matrix does not answer correctly
Jan 18, 2012 | Texas Instruments Office Equipment &...
Solve a matrix of complex numbers using ti89 or any other ti calculator
Well, the equation is Ax=b and we want so solve for x
There are several ways of entering the data, but this is one way
Code: A=[15+35i 29+1i; 46+13i 62+3i]
b=[0;0]
x=A\b which has the trivial solution x=[0;0] (the ";" means "next row", a space next column.) To input a matrix use APPs then Data/Matrix Editor then New. Then change Data to Matrix. Put in the name such as "AA" in the variable field. Then enter row and column dimensions. Then edit as a spread sheet. Use F6(util) to delete a column or row. To manipulate matrices, exit the matrix application, then go to MATH then Matrix. Notice that J(RowOpps) is available. Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
Dec 05, 2010 | Texas Instruments TI-84 Plus Calculator
Hp laptop screen gone sideways & mouse not working
Right click on an empty spot on the desktop, scroll down to the graphics control panel, this may be Ati or Nvidia. Open the control panel amd look to the choices on the left. There will be a choice to either "Rotate Display" or something about "Screen Orientation", change the rotation to "0" degrees or whatever puts it upright.
Jan 02, 2010 | HP Computers & Internet
Steps in solving matrix on my ti 89 calculator.
I assume you are speaking of solving a system of equations with a number of unknowns. If not, please correct me. Here's an example in practice:
If you have a system of 3 equations with 3 unknowns, you would set up your matrix so that the coefficients of each variable for a particular equation are on one row. So, given equations x + y + z = 0, 2x + 3y - 4z = 1, x + -z = -1 you would type the following into your calculator: [[1,1,1,0][2,3,-4,1][1,0,-1,-1]] and press enter to make sure you typed it correctly. notice that in the third row there is a zero, since we have zero time y for the third equation. Then row-reduce the matrix (2nd > 5 > 4 > 4 or in the CATALOG as rref). You should get out the matrix [[1,0,0,-1][0,1,0,1][0,0,1,0]]. This says that x=-1 y = 1 z=0 since my first column contained the coefficients for the x variable, the second for the y variable, and the third for the z variable. The last column contains the solution, the part on the other side of the equals sign.
Hope this helps! For more reading (from someone else; I just made this one up), check out the Wikipedia articles on Gaussian elimination and Systems of linear equations
May 03, 2009 | Texas Instruments TI-84 Plus Calculator
I need to know how to get to reduced row echelon form
i tried to graph a simple function but it wont show the lines it will only show the graph
Mar 17, 2009 | Casio FX-9750GPlus Calculator
Solving matrix
Go to your matrix button and enter a "3x4" matrix.
Then enter it as follows:
-3 4 5 7
4 3 2 9
-5 5 3 -10
Then exit out and go to "2nd->matrix->math->rref(". Then press enter.
Your screen should look like this:
rref(
Then go to matrix and select your 3x4 matrix, press enter and close it with a parathesis. Your screen should look like this:
rref([A])
Press enter and the screen should say this:
1 0 0 2
0 1 0 -3
0 0 1 5
So,
x=3
y=-3
z=5
Hope this cleared up the confusion!
SJ_Sharks
Mar 03, 2009 | Texas Instruments TI-84 Plus Calculator
Scroll lock in excel 2007
When SCROLL LOCK is on, "SCRL" appears on the Excel status bar. If you press the arrow keys when SCROLL LOCK is on, you scroll one row up or one row down. Or, you scroll one column to the left or one column to the right. To use the arrow keys to move between cells, you must turn SCROLL LOCK off.
Sep 18, 2008 | Microsoft Office Professional 2007 Full...
Texas Instruments TI-84 Plus Calculator Logo
2,128 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
