Question about Goodman CKL24AR24 Air Conditioner
I have a goodman gpg 10480901 a that turns on and the fan blows, but only blows warm air. It doesn't cool. Filter is brand new.
Posted by shari boyd on
william simpson
    Genius:
  • Goodman Master
  • 1,363 Answers
Compressor not running or low freon. try replaceing compressor capacitor.
Posted on Aug 14, 2015
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: Exhaust Fan (outdoor blower?) shuts off after 1 minute, and motor feels hot
sounds like your condenser fan (the outside blower) has gone bad or the capacitor (small silver box looking thing attached to the motor). the way to test the cap. is with a digital meter that can test for micro farads. the reason it gets hot is you have electricity going to the motor. normally it would transition that energy to motion energy. however since the motor is not turning that energy has to go some where, so it turns into heat energy. your best bet is to replace your condenser fan and capacitor. that is if your comfortable with that type of repair. otherwise call someone out to repair and tell them what your make and model is so they can bring the parts with them and save you some money. hope that helps
Posted on Jun 11, 2008
Therinnaiguy
Chandler Ede
  • 1420 Answers
SOURCE: My goodman seer 13 package
Is the outside unit starting and fan blade spinning? Have you inspected you air filter recently?
Posted on Sep 15, 2008
Anonymous
  • 614 Answers
SOURCE: I have a Goodman A/C unit. When I turn on the
Does the cpompressor come on if not the sound you here maybe the contactor. Check float switch inside. It is underneath the unit or in front of the air handler. Drain stopped up need to blow out drain. Check outside breakers. possible bad capacitor on unit. Need service tech. Rusty
Posted on Jun 13, 2009
Anonymous
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
Anonymous
  • 998 Answers
SOURCE: fan on outside a/c unit blows cool air, not hot as usual
change entire unit
Posted on Aug 18, 2009
Cold and hot stiky air
try cleaning the filter and fan blades.
Jan 01, 2012 | Heating & Cooling
Filter dirty and blowing warm air
If your filter is dirty,the fan inside the house cannot push the cold air thru the evaporator, cool air cannot circulate, this will cause the compressor outside to over heat and even damage it and possible trip some fuses or circuit breakers, with these hotter days you want to change out your filters more often, changing out your filters more often will keep the evaporator cleaner and allow the cool air to flow, easier.good luck!
Aug 08, 2011 | Goodman CLJ36AR42 Air Conditioner
Daughter moved into apartment and Goodman wall unit not cooling, no service till Monday. Blows air, just not cool. Anything I can do?
Make sure that the cooling control or thermostat is set below the ambient room temperature by at least 4 degrees. It may be a case that it was not set low enough to cause the compressor to turn ON. Only the fan is working.
If that doesn't help solve the problem, invite her to stay with you until Monday.
Thanks for choosing FixYa.
Aug 06, 2011 | Goodman Heating & Cooling
Takes times it will blow cold air no matter what, fan not working, then fan finaly kicks on and we get warm air.what is wrong?
Bad sequencer. An a/c tech will have to replace this sequencer due to the complications of installation.
Dave
Jan 08, 2010 | Goodman CLQ36AR49 Air Conditioner
I just moved into a brand new home that has cental air (Goodman air conditoner) how do I turn on?
turn the thermostat to cool and turn the temperature down if it still doesn"t run check for double pole breakers that are off
Jun 30, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman PGJ030075-1 Motor Not Spinning - No Cool Air Blowing
I assume you are talking about the evaporator fan motor. Check the capacitor. Replace if necessary. If cap shows good then it's most likely the indoor fan motor.
Jun 05, 2009 | Heating & Cooling
Brand new goodman 2 and half ton package unit runing all the time
Sounds like the Thermostat or board is wired incorrectly(being new)
have the installer come back and rewire it.
Please rate this solution.
Jan 16, 2009 | Goodman CKL49AR49 Air Conditioner
My goodman seer 13 package heatpump stopped blowing cool air. Fan still works, there is power to the unit.
Sep 15, 2008 | Goodman Heating & Cooling
Jun 11, 2008 | Goodman Heating & Cooling
Goodman CKL24AR24 Air Conditioner Logo
95 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
jdthefixer
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
