Question about Amana ASD2622HR Side by Side Refrigerator
Kitchenaid kssc42qms01 buzz's off and on - Amana ASD2622HR Side by Side Refrigerator
Posted by r rel on
1helpful
Kitchenaid model KSSC42QMS01 side-by-side refrigerator icemaker dripping
Sounds like it’s overfilling. Ice maker would need replacing if that’s the case. If it’s not overfilling and it’s dripping from fill tube, replace water valve.
Kssc42qms01 side-by-side. About a month ago refridgerator side was too warm. Removed top grill and cleaned coils. All was fine until today. High temp warning (beep) and both compartments now reading...
I just checked my sheets on this unit, this unit has to be turn off first, turn it back on and can only enter the service mode within 13 second after power up. Hold the filter rest then power button for three second. I hope this helps. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
2helpful
My kitchenaid diswasher will fill and drain with water but when the wash cycle starts there is a buzzing sound and nothing happens. Model 310253306 about 13 years old. The was cycle not working was not a...
The buzzing sound would be the motor trying to start and it not being able to turn...
either something is stuck in the pump and holding it from not starting or the motor its self has gone bad and will not start.
heatman101
Kitchenaid Refrigerator
Built in KitchenAid means your fridge is in the price range of $ 10,000/=.
Most likely the compressor and condenser on the top of the fridge. That is why you get the ringing noise. May be compressor not starting properly. Starting device issue or compressor seized.
Shut off the fridge and call a local service guy or Whirlpool Corporation. No time to test this and that. Your fridge worth $ 10,000/=. Don't be penny wise and pound foolish.
Kitchenaid KSSC42QMS01 refer is beeping. display is also flashing. cools normally.cannot enter diagnostic mode. Have not seen condenser fan spin, even while compressor is running. no voltage at fan
three things to check out.
1)the fan wiring's are they getting cut in between or burnt or short.
2)if the wires are proper ,then its faulty fan motor the Fan needs replacement.
3) if the compressor relay is faulty then also fan will not work.the relay is located beside the fan and compressor.
if not familiar with checking a local repair technician familiar with your brand /model is advisable.
to get required parts you can get it from
www.repairclinic.com
or from www.partselect.com
its a common problem occurs many times and checking /replacing the listed parts solves the problem.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Ice maker won't work
Check that lines are not frozen.
Check the inlet at the back of the fridge, ensure is not blocked.
Defrost unit completely to ensure it is not a frozen lines problem.
Check icemaker inlet valve, solenoid, and mechanics.
Here diagram and parts for your fridge's icemaker.
3helpful
Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Rubber door gaskets very warm to touch, ice cream soft, ice ok
the icemaker will work until the frezer gets to 17 then it will quit sound like a defrost issue defrost heater defrost thermastat or defrost timer need to get it fixed sooooooon you dont want to loose food at the price we have to pay
Amana ASD2622HR Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
