Hi Julie,
Have you checked all your connections? Where there any odd smells such as burning or anything of that nature? Any sounds when it starts to boot up?
Hi have you tryed reseting the bios , you need to remove the rear panel where the power and usb connections are , then lift off the lower small metal cover to expose the ram you will see a small blue jumper , lift this and move over 1 position so that the third pin is on the other side , leave for 10 sec or so then return the jumper back to where it first was . I forgot to mention make sure you have removed the power before trying this tho the cord would get in the way , if it does boot ok just remember to set the time & date .
• Unlock all of the channels on the TV by
entering "6688," which is the factory reset code. This code resets
the TV to original factory settings. Once this is done, you will have to go
through the initial setup.
• Call Omni technical support at (416)
260-0047. A technician can help you troubleshoot the television as the problem
may not be the child lock. You'll need to know the model number and serial
number of the TV.
•Take your television to a TV repair shop if you
are still unable to unlock the TV. The problem may be with the wiring, so the
repairman may have to rewire the TV
