Question about Chevrolet 1996 Chevrolet Blazer S10/jimmy S15 Radio
My 1996 V6 s10 blazer is stalling while at idle as well as when i am accelerating. when i try to start it up immediately after it stalls it will just turn over and will not start but when i wait for a while and try to start it, it will start up no problem but i can only go for a few miles before it stalls again.
Posted by Adrian on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: 1996 Chevy S10 stalls out 3 times before steady start
check for loose or cracked vacuum lines, and/or the rotor. It may not be making consistant contact.
Posted on Oct 30, 2008
Kruptd316
SOURCE: 96 Blazer stalls when hot on hotest days
I had a similar problem on my 95 jimmy. It was something that took a lot of time and money to diagnose, but now 3 years later...no proplems. Emissions requires the truck to have an EGR valve (exhaust gas recycle) and this deposits gunk (carbon residue) on your MAF (mass air flow sensor) If you catch it in time you can use a carbon cleaner from Autozone or checker Lightly on the MassAirFlow sensor. If not in time you may have to have either the MAF or EGR valve replaced and these are expensive. After a long period of time being undetected eventually the EGR valve will start smelling like sulfer, this means its to late to clean and save!
Hope this helps
Posted on Dec 01, 2008
dennymulford
Dennis Mulford
  • 1055 Answers
SOURCE: 91 s10 blazer engine surges warm and cold, stalls
tps sencor or maf sencor
Posted on Jan 24, 2009
David Shaub
  • 2976 Answers
SOURCE: Poor Acceleration Stalls at idle
Check the gas cap too. If the vent is failing, you will be getting a vacuum effect in the gaas tank. For every pound of vacuum, you will lose a pound of fuel pump pressure.
Posted on Feb 28, 2009
micah lenfest
  • 540 Answers
SOURCE: My 95' Chevy diesel k2500 stalls out when im Driving
I have replaced many injector driver modules on these diesels. GM has redesigned it and i have never had a replacement one fail. This is a known problem for the 6.5 diesel. Unfortunately its about a 500 dollar part from the dealer, and requires intake removal, and some very tight work space to replace.
Posted on Mar 22, 2010
Testimonial: "Thanks "
Fix rough idle and stalling on 1986 S10 blazer.only keeps running if pumping gas pedal. was running good and all of a sudden started dying out.
I would start by changing the fuel filter. Run some injector cleaner through it. And check for more of those rotten lines. You can check by spraying a little starting fluid around the vacuum lines. Be careful though. Its flammable. But the engine should speed up if you have a leak.
Mar 09, 2015 | 1986 Chevrolet S-10 Blazer
1996 S10 Blazer revs up and down and idles high. Stalls when smash on the gas? whats the problem
Idle air control motor. On the side of the throttle body. Either real dirty or bad.
Aug 06, 2014 | 1996 Chevrolet Blazer
Why does the car stall in my 1996 s10 chevy blazer while running?
A car stalls when the engine receives a sudden massive increase in load (think when you were learning to drive - releasing the clutch too quickly would cause the car to stall by transferring too much friction too quickly from the gearbox to the engine)
If the car only stalls when you are setting out from stationary then better engine/clutch control control is needed, or there is a problem with fuel or clutch. If it is an old car, try putting more choke on when pulling away.
If the car stalls all the time, the general reason is that there is probably either a fuel or an ignition problem causing the engine to cut out. Of course, there could be any number of things wrong with your car if it stalls during normal driving
Mar 10, 2014 | 1996 Chevrolet Blazer
96 s10 blazer idles high and stalls after tune up and replacing spider injector
Check the air filter box for fuel lying in it then pull the vacuum hose off of the map sensor and see if any fuel runs out of it.If you see fuel in either of these or both of them then replace the fuel pressure regulator.
Jun 10, 2012 | 1996 Chevrolet Blazer
I have a 95 S10 Blazer- vehicle code W (DI). The car starts fine but immediately wants to stall. If you press the accelerator you can keep it running and it runs down the road just fine until you slow to...
no its not the crank sensor if it were your car would not even start. your problem most likely is the idle air control valve, try removing it and and cleaning it if it does not help it will have to be replaced.
Nov 21, 2010 | 1996 Chevrolet Blazer
91 chevy s10 blazer.
have you checked the fuel pump? mine would shake rough then stall... i doubt it is the tune up but check the fuel stuff
Nov 22, 2008 | 1991 Chevrolet S-10 Blazer
Stalling
Look for a possible vacuum leak Use can of carburettor cleaner carefuly sprayed around inlet manifold and around injector seals.Spray with engine running and engine will instantly react to any leak no matter how small.Dont allow fan to blow onto paint as carb cleaner will damage it.
Oct 22, 2008 | 1996 Jeep Grand Cherokee
Oct 08, 2008 | 1996 Chevrolet Blazer
Chevrolet 1996 Chevrolet Blazer S10/jimmy S15 Radio Logo
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
