Question about Konica Minolta DiALTA Di200 Copier
Dialta 522 shows error C-0f24 which I believe to be a aidc sensor problem (1) where is this sensor situated (2) how do I repair the problem...can I just clean it if I find it (the sensor i.) Many Thanx
2 Related Answers
frankzjm
Frank Zhang
  • 191 Answers
SOURCE: My Konica 2300DL is showing
you may try bellow for your print trouble
1) clean laser lens cover using soft cloth,
2) perform an AIDC calibration cycle through the manu--- Engin/service/power on/test
reference user guide P81-82
Posted on Feb 10, 2009
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: I was just switching on a copier machine
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Posted on Jan 24, 2010
Testimonial: "Thank you it was finally helpful. The paper tray were not feeding because the "drum paper" was off. After i've turned on, the error code desappered."
How to remove c-24
1 PJ7A, CN10, and CN41 are plugged securely into Master Board. NO Plug them in securely. 2 Photosensor/LED of the AIDC Sensor are contaminated. YES Clean. NO Change AIDC Sensor Board. Change Master Board.
Dec 16, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Imaging unit need to change
The error is quite clear, contact your service provider and ask them to change it for you, or you can buy the imaging unit as well as the developer and do it yourself if you know how to run the toner density settings and aidc settings.
Dec 12, 2013 | Konica Minolta Minolta Di351 DiAlta...
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Of 24 error
Cof 024 - AIDC sensor contamination correction failure.The photosensore LED located under OPC drum of the AIDC sensor dirty.Clean the sensor,reset the malfunction code if the necessary perform F5 AIDC auto adjustment.
Mar 06, 2013 | Minolta Di550 B&W Laser Printer
Di450 errer cod c-0f24
COF24 - AIDC sensor contamination correction failure.Open the front door,remove(lossen 2 screw)the image unit,remove the drum and clean photosensor/LED of AIDC sensor.
Jan 03, 2012 | Minolta Office Equipment & Supplies
We have a Minolta Di552 copier with an error message C-0F24 on the display panel. What is the problem?
Has the developer been replaced? If not reset counter for developer without replacing the developer is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items then the copier will adjust certain voltages to certain items such as the drum and developer system as those they are new because you reset the counters when in fact he developer is old and so might be the drum which can cause codes and image problems. If the developer was replaced where the counters cleared !ST!!!!!!!!!!!!!!! and was the required F8 checked run? after installing. Also was the drum removed and the sensors cleaned by brush NO Vacuum cleaner. Static Electricty can destroy the the sensors.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 22, 2010 | Minolta DiALTA Di350 Laser Printer
Minolta Di470 Error code C-0F24
COF24 is an AIDC or Automatic Image Density Control failure code. It means that the machine can not properly detect the developer to toner mixture or ratio in the process/developer unit. This can be caused by an AIDC sensor failure, Developer Drive problem or for some reason the machine is not getting toner as it should. Has the machine been running low on toner?
Before calling for service I would try resetting the code by opening then closing the front door(s). Do this a few times and see if the code will go away. If not then you will need a service person to diagnose and repair which part is defective.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Office Equipment & Supplies
AIDC error code
When an “AIDC Error” occurs, do this:
1. Replace the Image Transfer Belt
2. Check to see if the AIDC Sensor is dirty
3. Securely connect the connectors to the High Voltage Unit
4. Replace PWB-A
Aug 05, 2009 | Konica Minolta magicolor 5430 DL Laser...
My Konica 2300DL is showing an error that reads AIDC Error and I cannot print anything
Feb 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Minolta DiALTA Di250
C0650: Faulty PC12 C0651: Faulty PC13
Relevant Electrical Parts Scanner Home Position Sensor 1 PC12 Scanner Home Position Sensor 2 PC13 Scanner Motor M5 Master Board PWB-A BCR Board BCR HGB Board HGB MFB Board UN2
Nov 06, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Konica Minolta DiALTA Di200 Copier Logo
70 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
Marvin
Marvin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
