LG enV VX9900 Cellular Phone Logo
A
Anonymous Posted on Sep 02, 2013
Downloading do not unplug - LG enV VX9900 Cellular Phone
I have a canon S2Is. I downloaded some pictures to my mac and unplugged it before the icon came up that said safe to unplug now the camera wont even turn on
This is why pros use a card reader for downloading. On my Mac, I right-click on the icon that holds my pictures and choose "eject -------" and when the icon disappears, I can unplug. Here's what I would try now in your situation: remove the card and battery...press every button...leave it alone for 20 minutes...insert the card and battery...turn it on. Plug it back into your Mac and see if the icon appears. Use my method for unplugging and if everything is successful, run out and buy a card reader to use from now on. typrice_254.jpg
Why i cant download my pictures to internet
Are you trying to downloading pictures to your computer? Try resetting your router for 5 minutes. To do this unplug the power cord from your router and leave it unplugged for 5 whole minutes. then plug in your router. Restart your computer and connect online. Try to download images then.
I am trying to download pics to computer i have already downloded software etc and have successfully downloaded other pics from cam since i have added a memory card when I plug cable to download into...
Blinking light means your computer still in process reading your data from memory card. Higher capacity of memory card would make the computer need longer time to read it. Just be patient and don't unplug the USB cable.
If you think its too long, then you can unplug the cable data, put off the memory card and open in via card reader so you can download your pictures to PC.
If useful, RATE please !
1helpful
I unplugged it from my mac while it was sill downloading, now the screen only shows "scandisk" thats it
That is too bad men.. unplugging device while downloading or synchronizing.
Try to reformat your mp3 or reset it first.
Cant see music when i unplug my sansa
See my tip posted here -->
http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
<---- copy and paste this address into a new window or tab.
8helpful
2answers
Lost the instaling cd for my brother dcp 135c
You can download drivers and software from brother website.
Download driver first.
Unplug printer usb before installing driver software, and start installation with printer usb cable unplugged.
Here the download page: Brother Software Download
1helpful
2answers
Lexmark T520 wont work!
To start do the following:
Unplug printer USB, unplug power from pc and also remove the battery if it is a laptop, and restart printer and PC.
With printer still unplugged go to control panel>>printers and empty the printer cue.
Test a replacement USB cable and try plugging the printer on a different USB port.
If the above did not work , then reinstall the printer software using the printer CD. Unplug the printer and start software installation with printer USB unplugged.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
What is the proper way to disconnect the camera from the computer?
Depending on the operating system that you work with, there is a proper way to disconnect your camera from your computer to ensure smooth operation. With Windows 98, you can simply turn your camera off and unplug it. Make sure you are not in the middle of downloading when you disconnect your camera, or you might loose some or all of your pictures. In Windows ME and Windows 2000, you must go to the system tray (on your task bar usually located on the bottom of your screen) and look for the "unplug/eject hardware" icon. Click this "unplug/eject hardware" icon once to pop up a list of devices available for disconnection, then click on your camera's drive. When the computer tells you it is safe to disconnect your device, then simply turn your camera off and unplug it. Windows XP also has an "unplug/eject hardware" system tray icon, which you should use. However, if you are not in the middle of downloading your pictures, it is generally safe to simply turn your camera off and unplug it. On a MacOS computer, you should drag the camera's disk icon to the trash can before turning off or unplugging it.
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
