Question about Danby DWC283BLS Wine Cooler
I cannot set the temperature ... Keeps resting 75 degrees F
Posted by Ruth McMullan on
Timothy Snead
    Problem Solver:
  • 6 Answers
How long does it take to reset? What is the temp are you trying to set it to? How old is the unit? Has it always done this or just started?
Posted on Oct 23, 2013
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
I bought a Honeywell RTH8500 thermostat and I can't get the temperature to go down past 75 degrees
You will need the installation book that came with the thermostat. There is a way to enter into the programming of the thermostat from the home screen. From there, you will need to find what code is the temperature settings in the manual, they are usually all 3 digit numbers. Once you find the code for the setting your looking for which is the lowest temp for the thermostat, it will have a 75 to the right of it which you can set a lower number. Sorry I do not have the manual right now to just tell you exactly how, but hope this still helps!
May 28, 2012 | Honeywell Rth8500d 7-day Touchscreen...
Oven is 75 degrees off temperature setting. what do I do?
Are you sure that no one has been taking the control nob off of the dial and turning it as a prank?
Feb 08, 2012 | Whirlpool Accubake RF362LXTS Electric...
My Trane ModelTCONT402AN32DAA thermostat set for 75 degrees overshoots to above 81 degrees (as measured by a reliable thermometer). The thermostat temperature indicates 75 degrees and the heatpump will...
I would remove front cover and see if your thermostat has a mercury switch.this will be a small vial connected to a bimetallic coil. The vial wiil be about 1/3 full of mercury. It will have a brite silverey appearence.There shoul be two leveling peg on inside of thermostat. Check the level with a torpedo level. it should be very close to level. If not loosen mounting screws that hold stat to wall and gently move base till you have it level. Hold base steady and tighten mounting screws. This should help thermostat setting and actual temperture to be closer. It's not unusual for setting to be off by several degrees.
Nov 15, 2010 | Heating & Cooling
I have never used central ac before - how do I set it? If it is on 75 will that cool the house? If I want it cooler, do I put it lower? like 65?
As to your question 'will 75 cool the house?' The answer is 'yes' - if the outside temperature is low enough. Typically speaking you can expect your central AC to cool a properly insulated house to a down to a temperature of about 20-25 degrees lower than the outside temperature. For example - if the outside temp is 95 degrees. You could expect to get your house down to 70-75 degrees. If the outside temp is 110 degrees then you could only expect to get the house to 85 or 90 degrees.
So .. as you can see - your 'inside' temp will be directly affected by the 'outside' temperature.
As to the operation of central air; it is very simple.
I would suggest that you not pay 'too much attention' to what you have the thermostat set on. A comfortable temperature - is a personal thing - so - I would set it somewhere - say 72 and see how I (and others in the house) was handling that setting.
If you want it 'cooler' just 'notch' it down a degree or two - if you need it a little warmer - turn it up a degree or two. Do this "fine adjusting" till you have the temperature setting you are comfortable with.
Usually the more you can leave your thermostat alone the better off you will be from a comfort position and an electrical useage standpoint. Obviously, the higher you have your thermostat set the 'less' it will cost you on your electric bill.
How high you set the temperature is a balance you have to come to based on how comfortable you want to be - matched with how much you want to hold down the electric bill.
hope this helps
Aug 14, 2010 | Honeywell Heating & Cooling
Danby DWC283BLS Wine Cooler Logo
181 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Danby Furniture Expert? Answer questions, earn points and help others
