If its just saying write protected, that means you cannot copy new information on to the disc, you should still be able to retrieve and copy information off of the disc. If you haven't tried already open up the disc from my computer, and you should be able to view the files and copy what you need.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
SOURCE: DVD-Rom drive doesn't work.
go to "My Computer" and right-click the icon representing the drive, then select "Eject." If that works, you know your drive is OK.
SOURCE: write protection
Get this program:
http://www.4shared.com/file/72797673/93a74bfa/UsbWriteProtect.html
You might need to get winrar from http://www.rarlab.com/
to open the rar file.
Extract all the files to a new folder, run the exe file and click the or disable Radio button and close the program.
Now remove the pen drive and plug it back in to the USB slot, Now open my computer and try to create a new folder in the pen drive, you can't. You get an error. That's what you wanted right? :-)
HTH,
Deboo
SOURCE: it won't let me open a password protected disc
very simple , if you have just deleted/unistalled a software which locks/password protects the system then you must reinstall it . Secondly you make sure you unchecked all the software functioning options inside when you open it now . Lastly try unlocking the system using the same software given capability to unlock if there is one (try several times if it doesnt work the first time), if it doesnt work then try unistalling the software again manually reinstall option given by the software and not through the control panel ,So then restarting the system and then see if its unlocked now.
Now to Say thanks just Click on the following Links:
Http://www.HazratSultanBahu.com
Http://www.Haqbahu.com
