If you receive a code without the #pw+ at the beginning or EG +1# at the end, then you need to add this to the code before you enter it.
For example, if you receive 418636523456123, then the code is actually #pw+418636523456123+1# (Should normally be +1# on the end).Please note: You only have 3 attempts to enter this unlocking code.
SOURCE: master reset code for nokia 1110i
The master code cannot obtained for free, as there is need to access a database.
It can be done at a local shop, or using the website below:
UnlockMe - Reset & read Nokia security code Tutorial - UPDATED
SOURCE: i want to reset nokia 1110i security code
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Dear user,
To unlock With-out entering the security code,
Just click on the unlock button ,then the back
button frequently.
then , press the unlock button again till a * will appear on
the screen for a very short period of time, press the *
button and you'll unlock the code without entering security code.
Normal
0
false
false
false
On the main screen , Press *#06# to get your IMEI
number,
Then just visit this website http://www.unlockme.co.uk/master.php?imei=354841017025585
And enter your IMEI code to get your Master code.
Your Master code will help you change your Security Code.
Best of luck. :)
