Kenwood eXcelon KDC-X679 CD Player Logo
Question about Kenwood eXcelon KDC-X679 CD Player
Unlock codes I wrecked my car and when I put mysystem in my new car my cd player will only play the tuner all other functions are locked so I need to know how to unlock it please.
5 Related Answers
Anonymous
SOURCE: Unlocking radio
I have this problem almost everytime I have to do it.  It's such a rare occasion.  If I remember correctly, just press and hold the key that moves you to the next number... the >>| key, I believe.  After a couple seconds it'll beep & open up (provided you have the correct code).
Posted on Oct 23, 2007
Anonymous
  • 93 Answers
SOURCE: need unlock code
this link can help
http://inform3.kenwoodusa.com/manuals/KDC-MP435U.pdf
Posted on Oct 29, 2007
Anonymous
  • 1512 Answers
SOURCE: Unlock code for my kenwood cd player
if its a kenwood try this :)
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Posted on Dec 16, 2007
Anonymous
SOURCE: Kenwood KDC-2025 won't play CDs
hey it does not play mp3 discs. u need a regular disc. mathews
Posted on Apr 04, 2008
Anonymous
  • 14 Answers
SOURCE: need the un-lock code for a kenwood kdc-422 car cd player
Type 1
Type 2
Type 3
Posted on Feb 04, 2009
I just put a cd in the cd player and now i cant get it to eject or play! do i need a code or anything to put a new cd player in?
check fuses.
if good, the player is jammed, service said player.
some players have a emergency eject feature. RTm.
every player is different , RTM for your player.
on some there is a tiny hole, you push in a paper clip and push
and it ejects.
others the lid must come off.
most stock or DIN radio heads, etc, need a special key to remove
them. unlocks it and then the head comes out with screws.
codes are for unlocking a locked head, (software, if not enabled
you dont have this.)
2answers
RENAULT TUNER LIST UNLOCK CODE
notify dealer for codes need vin and proof of ownership
WILL T-763 PLAY MY CD'S OR DO I NEED SEPARTE CD PLAYER?
That's a receiver only, so its only built in function is the tuner. You'll need a separate CD player, plugged into the CD input jacks on the receiver's rear panel.
2helpful
2answers
I took the battery out of and now my Kenwood Stereo asks for a code.
Reset the radio by pushing the small button on left side of the #1 preset. it is probably pulling the code for the anti theft protection. if you already have a lock code use it to unlock the tuner otherwise reset the tuner
It plays some cd
Well this happens because your CD player is region lock, and you need to unlock your player so that it plays all CD's. check your user manual for the region unlock code if the region code is not there then ask to your dealer for that code.
Good Luck!!
Thanks
Need to use Aux function with Satellite Tuner installed.
Yes, you will need to consult your owners manual (if you don't have one try Kenwoods website). AUX functions are turned ON during initial setup (like when you set the time).
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
19helpful
3answers
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Sony Xplod CDX-S2210S
It is more then likely your faceplate has become non functional, and if so the cd player is almost none functional. If you can remove the faceplate try cleaning the connections that clip into the cd player. But by the sounds of it, your face plate is die'ing out on you. Sorry
Good luck,
IF you need any more help just ask.
Thankyou
33helpful
6answers
Locked renault clio 2001 cd/radio player!
to enter your code when the cd player displays error leave cd player switched on and after 20 mins or so i will display 0000 then you will be able to enter your code this happens when some 1 has entered the wrong code
4helpful
Proline locking issues
The Proline manual (comes on a CD with the player) says:
6.3.7 Key lock
This function sets a time delay from when key lock function is started or the player is switched on, after which the player will automatically stop responding to the control buttons. Pressing any button will then display the message ‘Locked’. Key lock is useful, for example if you put the player in your pocket and don’t want any buttons to be pressed accidentally. The time delay is to let you start playing the music and so on. You can choose a delay of ten or thirty seconds, one, three or ten minutes, or you can disable key lock completely. •
Press and hold the V+ button for a couple of seconds to temporarily unlock the keys.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
