Motorola Mobility RAZR V3 Logo
Question about Motorola Mobility RAZR V3
Unable to charge
Phone will not take a charge or turn off. it says unable to charge
Posted by mwaqar2000 on
Anonymous
  • 89 Answers
You mobile software has some problem get it check with some one professional or claim they warrenty if it is there
Posted on Sep 14, 2007
1helpful
Unable to charge
motherboard is weekplz go to the motorola service centre
1helpful
2answers
Once i charge my phone i get a yellow light rather than green.
Leave it plugged in for a little while. When it's yellow it means that your phone is dead and it's charging up the battery. It will eventually turn on and the light will turn green.
2answers
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
V3 unable to charge
reflash the firmware this will correct the charging issues and if that does not fix it then have the mainboard replaced.
Feb 17, 2008 • Cell Phones
Phone says unable to charge
Try a different battery. If that doesnt work, it may be your charger port. Take an old tooth brush, turn off the phone spray alcahol on the toothbrush, and scrub the port on the phone. If that fails your charger port needs to be replaced. Check with your provider about the warranty. If its not under warranty, check my profile and we can help you for sure.
2answers
V3I, light turns on and then goes off. Unable to charge.
The phone usb needs to be either clean or replaced so take them to a repair center and have them service.
5helpful
5answers
Unable to charge
There could be corrosion on the charger, or the connection on the phone? If so, remove the battery and clean them both with a toothbrush and Isopropyl Alcohol. The phone may have gotten wet? Check behind the battery, there is a water indicator. Its normally white, if its gotten wet, it will be red. Best of Luck.
1helpful
Mobile Phone - Flip
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
1helpful
2answers
V3 dead but keypad flashing
I had exactly the same problem. After unsucessfully looking for a solution on the net I removed the simm chip and set it aside. The next day, I put it on PC usb charge and left it overnight. The next day, I powered it up and it worked. I turned it off and replaced the simm and it is now working fine. Go figure...
Top Motorola Mobility Cell Phones Experts
ADMIN Eric
ADMIN Eric
vince
Steve
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
