Question about Electrical Supplies
My garbage disposal is not working' only humming sound, no action. I'm not sure if I found the reset button. A red plastic, could be a button, on the bottom of my Badger was moved around, not so much pushed. What to do?
Posted by cindy on
Gil Shultz
  • 3,462 Answers
There is a wrench that came with your disposal. It is about 1/4" and has six sides. Be sure it is turned off. Insert it in the bottom in the middle and move back and forth a few times. Remove it turn on the water and try again. If it hums repeat. If no noise press reset, otherwise it is working.
Posted on Apr 30, 2014
5 Related Answers
Anonymous
  • 2992 Answers
SOURCE: BADGER GARBAGE DISPOSAL just humms. does not work.
It sounds like the disposer has something jamming it. Try using the breaker wrench supplied with the disposer (or a suitable-size hex wrench) fitted into the socket on the bottom. Rock the wrench back and forth to see if you can loosen the jam. Another trick is to use a wooden rod (end of a broom handle, for example) to push on the blade to try dislodging the jam. Look inside with a flashlight to see if there is something that is easily missed. (I have found drink can tabs, coins and a shelf clip that way.)
It's also possible the motor starting capacitor inside the disposer or the motor itself is bad, in which case you would probably spend less on a new disposer than on repairing this one. But a jam is more likely.
Posted on Jan 28, 2009
Anonymous
  • 247 Answers
SOURCE: garbage disposal leak
Don to install a new one.
don't think it is a DYI and by the time you call for service it would be cheaper and use your DIY.
Hope this is a FixYa
Please rate the answer
Kurt
Posted on Mar 23, 2009
Anonymous
  • 25 Answers
SOURCE: Resetting Garbage Disposal
should have came with a alen key use it. to loosen the blades that are stuck on the bottom of the gaburator theree should be a hole in the middle. Just fine a alen key that fits in the hole and turn it around and then turn it on should solve your problem
Posted on Jun 07, 2009
handygirl911
handygirl911
  • 66 Answers
SOURCE: The blades on my Badger 1 insinkerator don't move.
You will need to free the blades by inserting the food disposal hex key or a 1/4 Allen Wrench into the very bottom of the disposal in the center. After inserting the wrench you need to turn it all the way in both directions to free what has the blades held up. It may be hard to turn but afterwards pull the debris out from inside the disposal. Hit the reset button and it will work. Do not keep turning it on until you free the blade and then reset.
Posted on Jul 22, 2009
Fred Yearian
  • 5603 Answers
SOURCE: badger 5 garbage disposer does not grind
Some say to put a load of ice cubes in and run it.
Posted on Dec 30, 2009
Where is reset button on gemline garbage disposal
To reset garbage disposal follow these simple instructions:
  • Make sure that the disposal switch is in the "OFF" position.
  • Gently press the red button in to reset garbage disposal. ...
  • Turn on a cold stream of water and turn the disposal switch to "ON" position, the disposal should now run again
How to Reset Garbage Disposal InSinkErator
Ok so my moms garbage disposal had what I am assuming was a stuck flywheel, Will not run just makes humming noise, I deciided
Disposal is rusted out, and now shorted out.
Replace disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#install
Add comment if you need assistance while installing new disposal.
It should be fun.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Insinkerator model 55 hums
Copy following link for troubleshoot walk-thru:
Check that unit is receiving 80% rated voltage
Humming sound means start capacitor has gone bad.
Replace disposal.
3helpful
Garbage dispoal not working. The blades spin freely inside, the reset button has been reset, when you switch it on the moter makes a faint humming sound, and the allen wrench will not rotate either way.
You need a new disposal.
Free-rotating blades show there is no obstruction.
Humming says you have power.
Frozen allen wrench says bearings are rusted.
Motor is now overheating each timer electricity is turned on, and motor will overheat and stop humming.
At least the drain is clean and water is not flooding under the sink, which means you can continue using sink until disposal is replaced.
I wrote tips for installing disposal from days when I worked apartment maintenance:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
7helpful
2answers
My garbage disposal doesn't turn on, I checked the plug and it works. What do you think is the problem?
Every disposal I've seen or installed has had a RESET button. If there is no sound at all when you switch the unit ON, look/feel around the bottom of the unit for a small button (usually RED). Press the button in, and then try the switch again.
If the unit makes a humming sound when switched on, something is binding the mechanism and preventing the blades from spinning. If this is the case, unplug the unit and then spin it to remove blockage and free the blade mechanism. If the unit came with a large allen wrench, you can insert it in the bottom of the unit and turn it to free the blades. No wrench, no problem. Insert a small piece of pipe, a pipe wrench handle, or (my favotite) a 3/8 or 1/2 inch socket extension bar into the top of unit and turn the blade assembly until it spins freely. Once the blade assembly is freed, the unit should operate normally.
4helpful
The motor on my Badger 5 disposal was humming but not rotating. I cleaned out all the debris, reset it and now there's nothing - no hum, nothing. Is my badger dead?
The badger 5 has a dislodge device on the bottom right in the very center. An allen wrench will fit if you have lost the tool that came with it.
FIrts you will need to dislodge anything preventing it from turning. (Insert the right size allen wrench and turn both directions) The remove whatever comes loose after dislodging.
Then opush the red reset button on the bottom. Check the breaker that powers up the disposal, as you may have tripped it.
If the breaker is on, the unit is turning freely, and the reset button is pushed, then the next step is to check for power using a volt meter, to make sure the disposal is indeed getting power. If all the above has been done, the unit IS getting power then yes, the disposal needs to be replaced.
6helpful
3answers
My garbage disposal is not working. Making humming sound when turned on. I tried to press the red reset button but to no avail. Also tried to turn the little dosposal wrench in bottom hole of disposal but...
It is most likely plugged up there is a clap with a butterfly bolt that you turn counter clockwise remove the clamp and have a trash can under it and wiggle it to remove the lower half of the disposal, when it comes off dump it out and clean with fresh water. Then with hands free of the pump turn the disposal back on, it if still hums the motor is bad and you will have to replace..
Electrical Supplies Logo
Top Electrical Supplies Experts
john h
Robert Wooley
Robert Wooley
Are you an Electrical Supply Expert? Answer questions, earn points and help others
