Question about Dacor Ovens
SOURCE: Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Posted on Sep 22, 2008
SOURCE: Jenn Air electric double wall oven model ww2780B
A similar condition in our oven, finally resulted in an "F1" error message on the control panel/ keypad. A replacement of the control panel seems to be indicated. The part is available from several different jobbers: part # AP 4283616. A service call prompted our order of this part; hasn't arrived yet, but will post when in and working.
Posted on Nov 05, 2008
SOURCE: Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months). Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Posted on Nov 20, 2008
SOURCE: HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
Posted on Nov 23, 2008
SOURCE: Dacor double oven, lower oven works fine, upper
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Posted on Nov 27, 2009
