Coffee Makers & Espresso Machines Logo
A
Anonymous Posted on Sep 01, 2013
Directions on how to use Krups XP4000??? - Krups XP 4000 Espresso Machine
1 Related Answer
  • 102366 Answers
  • Posted on Jun 19, 2012
SOURCE: need directions on how to use Krups XP4000
You may download a copy of the manual from Krups here.
1helpful
2answers
Need directions on how to use Krups XP4000
My Krups XP4000 Espresso Machine has never been used. We tried to give it a try yesterday and it appears the pump doesn't work. You can hear the machine trying to do something but no water comes...
The pump is probably bone dry, you will need to put some water into it under pressure. I have a piece of hose in my workshop that fits the seal that the tank engages into, it's about 8 to 10" long. I engage the hose, fill it with water, activate the pump and seal my mouth over the hose and blow as hard as I can like I'm blowing up a balloon, it rarely fails.
I bought the Krups XP 4000 from a friend and did not get the manual. Where can I get one.
First of all, here is the main ONLINE SUPPORT page for your model:
http://www.krups.ca/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={BEA0CF2F-53AD-47A5-9346-AB81D1D03070}&SelectedProdRef=XP%204000%20Espresso%20Machine
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.krups.ca/NR/rdonlyres/7063A8E2-58E4-4823-B19E-FF5CE827D4EB/1200/XP4000.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
Thank you very much and good luck.
Apr 21, 2011 • Vacuums
My Krups XP4000 coffee machine gasket split. I have descaled the machine and replaced the gasket but water still sprays out of the side of the head and occasionally blows past the gasket. I replaced the...
I had the same problem .... My gasket split and I replaced it and water was still leaking past the gasket... Try this - Don't tighten the screen screw all the way...I have mine set at about 6 turns counterclockwise from fully tightened. Loosen the screen screw more if needed until the leaking stops... As a result, the gasket will sit lower and make a better seal with the portafilter lip.
2helpful
2answers
Directions on how to use a KRUPS type 963/b expresso machine
Unfortunately there is no result on Krups website for 963/b espresso machine. However, if you browse to the website: www.krups.com and choose any of the customer support options, l am sure they will be glad to assist you.
Best wishes,
Graemevm
Hi, I need a 'joint seal' for my Krups XP4000 expresso maker, and ideally also one for my old Krups XP 962 expresso maker. I got them in France where they are called 'joint porte filtres' ref cde MS 620342...
The part for your XP4000 is the brew head seal. A Google search turned them up here:
http://www.smallappliance.com/product.asp?cur=USD&cam=krups_parts&sid=18954&gid=18960&mid=15&pid=2870&prdCls=P&shopBy=Brand
This page is their Krups model list:
http://www.smallappliance.com/department.asp?cur=USD&cam=krups_parts&sid=18954&gid=18960&mid=15&shopBy=Brand
It doesn't show the XP962 but it gives their phone number and says to call if you don't see what you need. So maybe they can help.
In general, when you want to search for something on the Internet, start with a good search engine (I use Google but there are others of course) and give a search string like "krupps kp40000 parts". Then you can check out the links it gives you until you find what you need.
Krups XP4000 Pump Espresso Machine. It comes on and gets incredibly hot but no water ever comes through. It shakes a lot, makes a really loud noise when turned on. The tank is full and pushed in as far as...
If it is brand new you should not be expected to figure it out, take it back to the shop. Any messing about with a brand new appliance can only harm your guarantee, let them figure it out. It sounds like the pump valves are dry or stuck.
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
