Question about JVC RX-6018V Receiver
HOW TO TURN OFF AUTO MUTE ON MY JVC RECEIVER?
1 Related Answer
richroth
Richard Roth
  • 9472 Answers
SOURCE: I have a JVC RX
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Posted on Sep 01, 2011
JVC STERIO RECIEVER MODEL RX-554VBX
on remote try to un mute it is a ch only on not a and b or none use a ch only go in main menu of system cheak auto mute turn off
Jan 30, 2008 | Audio Players & Recorders
Jvc car radio won't mute on incoming calls
I think the only hope you may have is the radio has an auto signal select in the menu somewhere. You can't use the mute wire as that will mute the AUX as well.
Dec 08, 2013 | JVC Ks-bta100 Bluetooth Adapter For Select...
Receiver comes on but have no sound tried the solution; but it still didn't work. What I am seeing is, in the upper left hand corner of the window in small writing says "mute auto" which is...
Mute Auto is for FM only. It mutes interstation hiss while tuning. Look for some other indicator that might reveal why the signal path is failing. Tape?
Have you tried the basics? Speaker test? FM only?
Sep 01, 2011 | JVC RX-554V Receiver
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
I need to know the code to program a jvc av-32432 tv to a direct tv remote
Hello
The code for JVC with Direct TV Universal remote is:
10053
Programming DIRECTV Remote
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
OK.
Jul 06, 2011 | Televison & Video
I tried restoring the sound by pressing Muting on master volume. Auto Muting still appears on the display and I can't restore the sound.
"Auto Muting" is for FM reception only and means it will mute the FM audio unless the signal is strong enough to provide decent audio.
Re-evaluate your symptom and corrective actions for relevancy.
Manual / Troubleshooting Page 31:
http://www.retrevo.com/support/JVC-RX-6000VBKJ-Receivers-manual/id/315bh050/t/2/
Dec 27, 2010 | JVC RX-6000V Receiver
No sound in FM radio
I had same problom and fixed by connecting an antenna to fm port
Jul 05, 2008 | JVC RX-6030V Receiver
Mute auto
I had same problem and connected antenna to fm port and it worked
Feb 13, 2008 | JVC RX-778V
JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Dec 03, 2006 | JVC RX-618V Receiver
JVC RX-6018V Receiver Logo
Top JVC Audio Players & Recorders Experts
xxxxxx xxx
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
