Question about Health & Beauty
My vision sport power chair won't move. the
Posted by Kurtis Weber on
ernest a fleming
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Says here thats a right motor fault, check the right motor connections and cableing
Posted on Jan 20, 2014
Cmt HS-5600 scooter why does a wrench light indicator on joystick panel flashes 7 times when you move joystick in any direction?
When you turn the chair on and move the joystick the wrench light will flash you need to count the number of times it flashes to determine whats wrong ie 4 flashes pause 4 flashes pause. If its 4 flashes then you have a motor problem see my tips on flash codes to determine the problem. Whatever the problem is you will have to have the chair fixed by a tech or the provider that sold you your chair Hope this helps
also found this
Many times a brake lever reset can resolve this issue that is preventing the PWC from operating.
MPV5 - The brake levers are located on the front of the Power Wheel Chair just above the footplate. To reset the brakes on the MPV5 Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
TEK FWD and TEK XHD - The brake levers are located on the front of the Power Wheel Chair under the label that reads "Drive" and "Push". To reset the brakes on the TEK FWD or XHD Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
If the lights on the controller continue to flash make sure the controller is not locked.
Aug 28, 2018 | Ez Access Health & Beauty
My Invacare pronto m41 service light flashes 7 times, what does that mean and how can I fix it
Hi 7 flashes possible remote fault :::::::::: CHECK IF JOYSTICK IS CONNECTED PROPERLY, cheers
Jan 31, 2018 | Invacare Health & Beauty
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
My jazzy 1170xl plus won't move. When I power it on the lights come on like there supposed to but as soon as I move the joystick the battery level lights start to flash rapidly. 9 of the 10 lights...
Code 9: brake fault. Check motor connections and make sure that the levers are in the engaged position - if you can roll the chair the gearbox is not engaged.
Apr 29, 2013 | Pride Mobility Products Jazzy 1170 XL Plus
Why are the lights blinking and it won't go
read manual,lights flash when in security mode,everyt model has a unlock procedure with the buttons on the joystick control.
Jan 23, 2013 | Pride Mobility Jazzy 1143 Power Chair -...
Issues with Streamer Sport Model 888WA power chair
please can you tell me how ofter the light's flash ? does there appear to be some kind of sequence ?
Dec 09, 2012 | Shoprider Streamer Sport Power Wheelchair...
When switched on power light flashes.
How many flashes? Count number of flashes should be a slight pause then flashes the same number of times . Your manual will give you flash codes and you can determine what the problem is. If all the lights are flashing and there is no pause the chair could be in "lockout" Your manual should tell you how to get the chair out of lockout I think that Pride uses the joystick to get it out of this mode.. Turn the chair on move the joystick forward till you hear a beep then move the joystick to the rear until you hear another beep release the joystick and the lights should quit flashing Hope this helps
Aug 12, 2010 | Pride Mobility Products New Pride Mobility...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
Feb 17, 2010 | Jet 3 Ultra Power Chair
Lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Health & Beauty Logo
104 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
