Question about Whirlpool Washing Machines
Cae2743bq will not turn on all lights on and lid lock is lit up
Hector Soto
    New Friend:
Try this, worked for me! :)
New WHIRLPOOL Top Load Washer
Model #'s CAE2743BQ, CAE2763BQ
Cycle Selector Knob key dance: [CCW=Counter Clockwise and CW = Clockwise]
Start On "NORMAL"
1 step CCW (Left)
2 steps CW (Right, Right)
1 step CCW (Left)
1 step CW (Right)
Stay on "HEAVY DUTY"
(If unsuccessful LEDs will not flash, and you must return the selector to the Normal Cycle position and
wait 4-5 seconds before retrying. )
If you are successful in the process, all LEDs will be flashing
Toggle between HEAVY DUTY and NORMAL until ONLY the RINSE light is on, then press the
START button for about 30 seconds. Machine will then enter CALIBRATION mode for about 2 - 4
minutes. DO NOT RAISE THE LID
Posted on Jul 10, 2014
HOW CAN I DO A LID LOCK TEST
Place unit in diagnostic turn knob till rinse and spin are lit press the start button lights should go out press start again the lid should lock light on press again unlock and off
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. top load...
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
Single mother of four wash machine not working only 2 yrs old.
Take off electricity wire, Open the filter from the front( maybee need to remove a rectangular cover.) turn the filter anti-clockwise. take out the hairneedle or coin. (the water will come out from the filter so make preparation with towels., see inside the filter if something is stucked around the small propellar. Turn the electricity back on. choose for example pumping program or centrifugeprogram. After that the machine should work.
Jun 01, 2013 | Whirlpool Washing Machines
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
The progress light indicators says it washing and the spin light is also on at the same time when I press the start button the lid lock light comes on the other lights go out but washer still won't run...
Hi just read your posting.To help you repair this fault I need the model number of the machine.Also in your posting you mentioned that some lights were lit.They are in a row of 8 lights/Starting from left to right which lights are lit.Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with the additional information and I am sure I can help you.
Sep 01, 2010 | Fisher and Paykel Washing Machines
Neptune TL locked lid light stays lit
foxste
I will give you a few things to try that are non technical and let’s see if the Control Board will let you in Service Mode. If so we will try lock and unlock the washer in Service Mode.
The Service Manual for reference. Sears Parts Direct for reference.
Let enter Service Mode;
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Board Output Test
While in Service Mode, pressing the Delicates key will begin the Board Output Test. This test turns on a
specified output after a key press. (Pressing the Delicates key again cancels the test.) All outputs
will be turned off after five (5) minutes.
Now Press the Colors / Jeans key this should lock the Left and Right Lid Locks….. did it?
If the lid locked now press the Extra Rinse Key and this should Unlock the Left and Right Lid Locks….. did it?
Let me know and we will go from there. I’m trying to get a feel for what Control Board functionality you have……Rich
Apr 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The locked light is on but I am able to open the lid. It will not start
Hello barbarafreel,
Your machine type is a FAV6800A correct? If so I would try to recycle 120VAC power to the machine. Pull the washer power cord for 30 seconds then repower backup. Do you still have the Lid Lock LED lit? If so further trouble shooting is required. I would next have you go into Service Mode. Once in Service Mode we need to go Board Output Test on page 16 of the Service Manual I will summarize below.
Here is the FAV6800A/FAV9800A Service Manual for your machine. Follow all safety warnings when working on the machine.
Let’s see if you can get into Service Mode, from the Service Manual slightly modified;
Enter Service Mode by pressing and holding the Enviro Plus and Spin Only keys simultaneously for three seconds or the display reads “00”
Now look at page 16 of the service manual let’s see if you can with the Board Output Test function unlock and lock the Left and Right Lid Locks.
Now press the Delicates key.
The LED display should show ot and the Quick Wash led will be lit.
The Left and Right Lid Locks will lock.
Now press the Extra Rinse key pad.
A few seconds should elapse and the Whites led will go lit for a short duration then off and in a few seconds the Lid Locks should unlock. Do the Lid Locks unlock?
Now press the Colors / Jeans key pad again.
Do the Lid Locks lock?
Let me know what action took place and we will go from there.
You can get out of Service Mode by pressing Enviro Plus and Spin Only keys simultaneously or press the Off key.
What I suspect is one of the lid lock is not releasing completely which moves a slide switch in the lid lock to signal the control board that the Lid is Unlocked and the Lid is Locked.
If you still have the issue I would release the washer top form the base and unplug the Right Lid Lock and see if that right lid lock is signaling incorrectly and possibly causing the issue. The Service Manual will show you how to release the washer top from the base. The left lid lock because of its dual signaling function “the Lid is Open/the Lid is Closed” and “the Lid is Locked/the Lid is Unlocked” can’t simply be unplugged. If you pull the Left Hand Lid Lock plug you will show a OP or OD error from the Control Board. If you are up for the troubleshooting I will help you proceed further.
Only the Left Lid Lock assembly needs to be plugged in for the washer to work as designed. I removed my Right Lid Lock a year ago and would never spend the money to replace it my choice.
Dec 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Lock light wont turn off
Hello shon95m,
Glad to hear you did some troubleshooting on the first go around of your issue, we need to do some more. I haven’t experienced this issue but will troubleshoot with you if you can tolerate the down time. I will be doing this from the schematic of the machine. In this condition with the Locked LED lit are the Lid Locks actuated not releasing the lid to open? I know you know how to release the washer top from the washer base. Can you get into Service Mode in this failure condition?
First I would try the first two bullet points on page 13 of the SM for Will Not Unlock. I think you may have it, if not here are a couple of links to support troubleshooting efforts; Service Manual for reference. Sears Parts Direct for reference.
If that produces no results I would next pull the right lid lock off and leave it off it’s not necessary for normal washer operation and we need to reduce the failure points for fault isolation causing the lid lock circuit to remain lit.
Pull washer power plug first then pull the right lid lock off and leave it off. With the right lid lock plug pulled power up the machine does the Locked LED remain lit?
Repeat the step for the left lid lock after machine power up dose the Locked LED remain lit?
The “Lid Is Locked” inputs to the control board are in parallel from the left and right lid locks. From the schematic it looks like when the lid is locked +12VDC is connected thru the left and right lid locks to the input of the control board via Pin 8 of connector P3 marked on the schematic as “Lid Is Locked” input to the control board. From the schematic it looks to me that +12VDC signals the control board that the lid has successfully locked. So what is causing the Lock LED on the console? If it’s not caused by +12VDC switched to the input of the control board marked “Lid is Locked” from the left lid lock then I feel the control board has failed at component level causing this issue, but that is a WAG right now. The SM also speaks to a possible Motor Controller board as a possible fail point. If the Lock LED goes out when we pull the plug on the left lid lock then we need to open up that left lid lock and inspect for a possible corrosion paths at the plug or the left lid lock. See pic below of some nasty corrosion that can cause issues with the left lid lock assembly. Maybe we can get some other forum members to offer some additional support. I will continue to help until I hit a brick wall in troubleshooting or you need to move on. Rich
May 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
3,356 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
