SOURCE: 2001 dodge ram 1500 extended cab
Firstly, this is assuming that this is a 5.2 or 3.9 engine. The newer 4.7 modle would be totally different.
Sounds like a intake gasket issue(#3) intake gaskets and a belly pan gasket were quite common place one these modles.
(#2) The passing gear or kickdown is adjustable at the throttle body
(#1) This sound is quite likely normal for this truck. Have heard of many trucks sounding the same and at the time it was normal.
SOURCE: Engine running hot displays on dash....cold air blowing thru vent
there,s a chance that your hot-cold air trap is not working
SOURCE: engine wont idle unless you keep your foot on the gas pedal
First, try a new accelerator pump. They're less than $10 and easy to install. On the side of the carburator, near the linkage. It's simple a small rubber diaphragm.
SOURCE: toyota echo gas tank hose shuts off gas
I hear an answer to this problem was that the overflow tube was blocked.
