Question about Nokia mobile C2-00 Dual SIMbiosis
Operation required sim card under battery - Nokia mobile C2-00 Dual SIMbiosis
Posted by swarnjeet on
bala
    New Friend:
Problem with Nokia mobile C2-00 Dual SIM
Operation required sim card under battery Please Help me
Posted on May 07, 2014
a g mani
    New Friend:
Posted on Aug 02, 2014
Tip
Phone displays "SIM card rejected" or "SIM card unaccepted".
The SIM (subscriber identity module) card is a small card inside your phone that establishes a network connection. The SIM card is provided by your operator or service provider. In most cases, they are the best source of assistance with SIM card problems. Your phone may display a SIM card error message if:
  • The SIM card is out of alignment. If the phone has recently been dropped, bumped, or opened, the SIM card may need adjusting. Follow the SIM card installation instructions in your user guide.
  • The PUK (Personal Unblocking Key) code is entered incorrectly multiple times. This can inactivate the SIM card. If inactivation appears to be permanent, contact your operator or service provider for a new SIM card.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. It may also be that your phone is configured so that it cannot be used with a SIM card from a different operator or service provider. Please contact your current operator or service provider for assistance.
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider to have the SIM card tested and/or replaced. Or alternately, bring your phone to the nearest Nokia Care point for inspection
on Sep 12, 2010 | Cell Phones
Tip
SIM card Rejected ? orvSIM Card unaccepted?
The SIM card is the small card inside your phone that establishes the network connection. In almost all cases, your operator or service provider is the best source of assistance with SIM card problems.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. Please contact your current operator or service provider for assistance.
on Mar 14, 2010 | Cell Phones
Operation requires SIM card under battery
To get a SIM card, contact your cellular service provider.
Sep 17, 2016 | Nokia New Factory Unlocked 206 Dual Sim...
Operaction required sim card under battery ?
Yes. If you are using a GSM phone, it's operation requires a SIM card. Get SIM card from your Mobile Service Operator,
Jul 12, 2015 | Nokia Cell Phones
I need to replace the sim card
In almost every cellphone the Sim Card is located under the battery. Open the back of your phone where the battery is located and remove the battery. You should see the Sim Card that you want to replace. Most Sim Cards slide under a small holder. Gently slide the Sim Card out. Make sure that you are aware of how the old Sim Card is positioned so that you can simply slide the new Sim Card in exactly the same way as the old Sim Card came out. Replace the battery and close the back cover and you are finished.
Oct 05, 2012 | Motorola Mobility V950 Cell Phone
Klg8700 have a sim card?
Cell phones (used in the consumer markets) use two types of "Networks" to operate.
1st is the CDMA network, it DOESN'T use a SIM card.
2nd is the GSM network, it DOES uses a SIM card.
If you have a SIM card it is located directly under the battery in a slot, it looks like a tiny credit card.
Dec 12, 2011 | LG Cell Phones
Phone keeps saying invalid sim
Messages When You Turn on the Phone
  • When turning on your phone you may find a message requiring you to take a certain action before you can use the phone. If the message says "INSERT SIM," make sure the SIM card is installed in the phone or that it hasn't become loose. The SIM card is located in the battery compartment. Remove the battery cover and the battery. The SIM card should be located near the bottom of the phone under the metal hinge. Insert or secure the SIM card with the contacts facing down, reinsert the battery and batter cover, and turn your phone on again.
    If the message reads "PHONE LOCK," the SGH U600's automatic locking function is enabled. Enter the phone's password to unlock the phone.
    When using the phone for the first time, you will be prompted to enter a PIN. The PIN is given with the SIM card for your phone. Enter the PIN number exactly as given. You may also have the "PIN Check" feature enabled on your phone, which will require you to enter the PIN every time the phone is powered on. You can turn off "PIN Check" in the "Settings" menu.
    A message asking you to enter a PUK means you attempted to enter the PIN number three times and failed. You must contact your service provider to get a PUK.
  • Read more: Samsung SGH U600 Troubleshooting ' eHow.com http://www.ehow.com/way_5408527_samsung-sgh-u600-troubleshooting.html#ixzz11rVbifG3
    Oct 09, 2010 | Samsung SGH-U600 Cellular Phone
    In my dell studio 15, there is a sim card slot at the battery compartment. what is the function of it?
    That slot is an ExpressCard Slot for WWAN cards that require a sim card in order to connect to the provider's network. Not all WWAN cards require sim cards to connect. If you get an ExpressCard WWAN card, and that card requires a sim to connect, then usually there will be a place on the card itself to put the sim. The sim slot in the battery bay is because most mini-cards do not have room to add the required sim card slot and still fit into the system.
    Nov 10, 2009 | Dell Wireless 5530 Mobile Broadband...
    Cell Phones Logo
    1,195 people viewed this question
    Top Nokia Cell Phones Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Zaid Anarwala
    Zaid Anarwala
    SANTHOSH
