Question about Motorola Mag One Bpr40 Uhf 4w 8 Channel Two Way Business Radio Used
Mt mag one bpr40 uhf 450/470 will receive but will not transmit. green light is on all the time
Posted by Dennis Demas on
Randy Reynard
    Master:
  • 623 Answers
It probably has "busy channel inhibit" turned on in the menus, and the squelch is open, thus making it think there is a signal on the channel you're trying to use.
Posted on May 04, 2014
1 Related Answer
eradiostore
eradiostore
  • 1664 Answers
SOURCE: How do I connect Mag
The Mag One BPR40 is dealer programmable. You have two choices:
1) Reprogram your CP100s to match the new BPR40s. For this you would need to know what the dealer programmed the BPR40s to... OR
2) Take your BPR40s back to the place of purchase and request they reprogram them to match your CP100s. This should be a free service since you just purchased the BPR40s. They will need to know some settings from the CP100s to make the match.
Best regards.
Posted on Sep 19, 2011
Will not transmit or receive
Contact Motorola Solutions. Get Support .
Mark
Motorola Mobility Support
Jul 17, 2015 | Motorola Mag One BPR40 Two Way Radio
How to I syncronize all my radios so they work together
Karen-
Get Support
Mark
Jan 09, 2015 | Motorola 4 Magone Bpr40 Uhf
Mag One BPR40 not powering
Contact Motorola Solutions (http://www.motorolasolutions/support)
Jun 26, 2014 | Motorola Mag One BPR40 Two Way Radio
Mag one wont get reception
First you check the volume, turn the volume, then you check your speaker. If both are ok then you check QT and DQT. These character must be same.
Jan 14, 2014 | Motorola Mag One BPR40 Two Way Radio
Green light stays on bpr40
If this is after programming your radio needs repaired. We see this when some BPR40s are reprogrammed. Take the radio to your local service center or send to a qualified repair center.
Sep 12, 2013 | Motorola Mag One BPR40 Two Way Radio
My mag one bpr40 will not transmit. the green light is on all the time. it will receive. how do i fix this problem
Green light coming on and staying on... Sadly nothing the end-user can do to alleviate this problem themselves. It is usually repairable by a trained/equipped repair facility.
Sep 01, 2013 | Motorola Mag One BPR40 Two Way Radio
Have two bpr40 need to find out the frequencys
The BPR40 is a dealer programmable radio. The frequencies would need to be read out using Motorola proprietary software. The only thing you can tell from looking at the radio is whether it is VHF or UHF. Model number AAH84K... is VHF and AAH84R... is UHF.
Best regards.
Aug 20, 2013 | Motorola Mag One BPR40 Two Way Radio
The green light that indicates that some one it talking and goes red when you key always slays on
This is an indication of a receiver problem. Two things cause this. The receiver needs to be realigned or you have bad ceramic filters that need to be replaced.
Sep 12, 2011 | Motorola Mag One BPR40 Two Way Radio
My magone BPR40 radio isn't sending when PTT is pushed. It is receiving fine. Any suggestions?
A couple of thoughts:
1) Check the mic hole and see if it is covered or clogged with debris.
2) Does your PTT button seem hard or the opposite, mushy? You could have an internal PTT issue. The PTT is a common failure part on 2-way radios. Feel around for the 'sweet' spot and see if you can make a simple or partial transmission, or if it will even momentarily open up the receiver on the other unit. If so, your radio is in need of repair. It would likely need a new internal PTT. (At most repair centers where the BPR40 is repaired the flat rate repair currently are around $69 for the BPR40)
3) Has any reprogramming been recently done on the radio? If so, double check the programming to be sure your PL/DPL code is set the same as your other radio.\
4) Check your battery. Trade batteries with the other unit and see if the problem changes. It takes more energy to transmit than to receive.
Best regards.
Jun 15, 2011 | Motorola Mag One BPR40 Two Way Radio
Motorola Mag One Bpr40 Uhf 4w 8 Channel Two Way Business Radio Used Logo
203 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
