Question about Metz 45 CL-1 Flash
Nikon D60 + Metz 45CL-1
Can I use my Metz 45CL-1 flash with my Nikon D60 Camera
Laszlo Kalmar
    New Friend:
  • 30 Answers
Yes, you certainly can use the Metz 45CL1 flash with your Nikon D60 - with some restraints.
1. The flash must be set to "Computer Mode", you may chose one of the working apertures on the flash so that distance of the subject fall within the covered distance for the given aperture.
2. The camera must be set to full manual mode; the aperture have to be the same as on the flash. The exposure time must be set to 1/125 sec. (For creative photography longer expositions can be set.)
A simple hotshoe to PC cable fires your flash.
This way the Thyristor Computer in your flash assures the flash will illuminate the subject with the proper amount of light. It also works well with bounce flash, provided the flash sensor is aimed at the same subject as your camera lens. Angle of coverage of Metz 45CL1 with a wide angle diffuser allows using a 18mm lens, wlrhout - a 24mm one.
Good light!
Posted on Nov 25, 2014
Doberman
  • 261 Answers
Get the Nikon AS-15
Posted on Nov 19, 2014
5 Related Answers
Anonymous
  • 216 Answers
SOURCE: mating Metz 60CT4 to Nikon D80 camera
The 60CT-4 was not made for digital cameras.
It does TTL on film not on CMOS or CCD sensor.
Alexander
[email protected]
Posted on Dec 14, 2007
Anonymous
SOURCE: Metz 45CL-4 Service Manual wanted..
Hi !
Here is a link to the Metz manufacturer:
http://www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
I hope it will be to some help.
Regards Lars
Posted on Feb 27, 2009
Anonymous
  • 7 Answers
SOURCE: Metz 58 AF with Nikon d90 wont flash
If you hear rattling or a grinding sound/feel .. can be flash tubes broken.
Posted on Jul 21, 2009
Neil
  • 22 Answers
SOURCE: Metz mecablitz 45 ct 1 and Nikon D-90
The trigger voltage of the 45CL-1 is about 12V, so it should be safe to connect directly to the hot shoe with an adaptor, or to the pc soclet, if the D90 has one. If the D90 is anything like my Canon 40D, which can stand about 30V on the hot shoe, then all the 45CL series will be ok, as they have trigger voltages between 9V and 12V. The 45CT-5 has a trigger voltage of 15V and works well on the 40D. I use 3 different Metz 45 models with my 40D and all work well on automatic, where the flash sensor itself controls the light output.
Posted on Aug 20, 2009
Anonymous
SOURCE: Metz 45 CL Flash to use with Nikon D90
Metz in Germany advises Models CT45-1 with Serial No's 53400 or less have High Voltage triggers and must not be used on NIKON Digital Cameras Models D70 ,D80, D90 etc.and will damage Flash and even Cameras. according to a email received today. 21/09/2009 Models CT45-4 and 45CL -4 ore ok.
Michael T
Posted on Sep 21, 2009
Can metz 45CL-1 support Nikon D5100?
To use Metz 45CL-1 with Nikon D5100, you need use in apperture priority mode (A), adjust same ISO and apperture in Flash and Camera (Ex: ISO400 and F: 5.6) . The flash adjust light intensity to mantain correct exposition. You need use an adapter to conect Sync cable in your camera.
Nov 13, 2015 | Nikon D5100 Digital SLR Camera With...
I dropped my camera now the flash is broken,
yes of course, there are a lot of brands that compatible with Nikon D-60 e.g Nikon itself, Metz, Vivitar, Nissin, Yong Nuo, etc.
The flash with iTTL support would be an advantage
iTTL is the feature Nikon has to measure the perfect light produced from the flash from the condition of the object
hope this advice help you with your problem
May 10, 2010 | Nikon D60 Digital Camera
Metz 45 cl-1 speed light & nikon d60
If the shoe of the flash is compatible with the hot shoe of the camera then yes go for it. Should the flash shoe be different then the flash will still work but with a shoe adapter. Both are TTL so I see no reasons why they won't work. I do know of a friend who uses the Nikon with the same flash but it has the battery pack fitting and uses an adapter on the camera's hot shoe. He does weddings galore and never had a problem even though he carries a spare he has never used it.
Apr 22, 2010 | Nikon Speedlight SB-80DX TTL Flash
Hi My Metz 45cl-4 asa control on the hammerhead
yes it can be repaired use a WD 40 spray on asa dial try it
Oct 10, 2009 | Metz 45 CL-4 TTL Flash
Michael T
Mar 20, 2009 | Metz 45 CL-1 Flash
Jan 26, 2009 | Metz 45 CL-1 Flash
Contacts voltage
Originally the 45CT1 had high trigger voltage. In the production period Metz improved it to a much lower voltage release circuit. Metz homepage (metz.de) holds the information, from which serial number on have 45-CT1s low trigger voltage. However, even the high trigger voltage was lower than 200 volts, thus safe for your Fuji.
Laszlo
May 03, 2008 | Metz 45 CL-1 Flash
Metz 45cl
I found th answer in the manuel. You can not use flash when pluged into charger.
Apr 24, 2008 | Metz 45 CL-1 Flash
Metz 45 CL-1 Flash Logo
233 people viewed this question
Top Metz Cameras Experts
Marvin
Marvin
Harrie
Are you a Metz Camera Expert? Answer questions, earn points and help others
