Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
D52wlcd zenith rear projection 51 inch flat screen tv
Posted by check lamp on
Anonymous
I was watching a movie and the screen went black i do have sound. what it can be?
Posted on Nov 25, 2008
2answers
4helpful
Tv wont turn on... light blinks yellow as if its going to power on.. and just shuts off... for my zenith dlp 52 inch tv
I had this same problem. The Zenith rep told me to unplug the TV, hold the power button down for 30 seconds, plug it back in and then turn it on. It worked and I haven't had a problem with it since. I hope this helps. Good Luck!
52 Inch Zenith TV has red blue and green squiggly lines what is wrong, no picture
I belive that the red light means that it is off and the blue means that its on
1helpful
52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
Zenith d52wlcd 52 inch rear proj. overheating symbol appears within 2 hours of operation
some solutions
1 clean fan
2 lamp reaching end of life. replace
3 seak profetional help
How to reset lamp hours
try holding the enter button on the tv and the mute button on the remote. a reset screen will pop up and then just press the center direction button twice.
Reset Lamp
Look in your owners mannel if you still have it,it should tell you lamp reset code.
1helpful
ZENITH D52WLCD
I just found the solution on another model of Zenith TV. Hold the enter button down on the TV and the MUTE button on the remote. In approx. 5-7 seconds a screen will pop up asking if you want to reset the lamp timer. Hit the bullseye button in the middle of the arrows and it will reset. Worked perfectly.
Zenith M52W56LCD blue spot in center of screen
It could be as simple as dust contamination in the LE or lcd chip. You need a clean room to work on this area of the unit and NOTHING you can do there would make that possible, short of spending a few thousand to build one. Before we added a clean room enviroment we simply pulled the LE and sent it in to PTS - who has one and reinstalled...
In your case take it to a qualified shop and you'll save yourself a lot of grief..
Bill
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
