Question about Dewalt DW421 5'' orbital sander
Dewalt 5" sarder rotatesvery slowly - Dewalt DW421 5'' orbital sander
Dewalt table saw stopped working
most like its damp, or the bushes need replaced, check the fuse in plug and also at source meter board for a triped fuse
Nov 12, 2012 | Dewalt Saws
How do I unlock the chuck to get the bit out
Finally got it the normal way. Put the drill in reverse. Hold the outside ring very firmly and slowly run the drill (in reverse direction). It was stuck. After about 5 bursts on the trigger, it finally came unstuck.
Sep 01, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How to change the blade?
I don't know if this will help you much but I've got a DeWalt 14 inch chop saw and a 10 inch miter saw and they both have a small lever on the right hand side of frame just behind blade If you depress this lever and slowly rotate blade until it drops into place this locks the blade for changing. Hope this helps you. Thanks.
Nov 22, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Drilling slowly
If the battery is OK then the problem will be in the variable speed trigger switch.
Sep 24, 2009 | Dewalt DW999K 7/8" Cordless SDS Rotary...
I have a dewalt DW092PK and i am unable to get it to level. can get it two ways but when i turn it 180 deg i am way out of level not just a little was wondering how to corect this problem and if it is...
as you set up make sure your top of the tripoat is as level as possibel , than before ,you skrew on your dewalt adjust all the adjusting weels to the middel, than hold it lose ontop of the tripoat check the bubbel for level if near than skrew it on and further adjust with the adjusting weels [slowly] if ok turn it 180deg and adjust ones more than again 180 dg turn if close you set .
May 01, 2009 | Dewalt Factory-Reconditioned DEWALT...
DeWalt Heavy Duty Cut-Out Tool (roto zip) DW660
dewalt dont make 5/32 collar for the DW660. best option is to ask the guys that sales store carry woodworking stuff.sorry man
Jul 05, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DW421 5'' orbital sander Logo
42 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
efs_perpends
efs_perpends
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
