Question about Icom IC-R8500 Base Scanner
What kind of bulbs inside? - Icom IC-R8500 Base Scanner
Fix a burned out light bulb on dryer?
there should be a light bulb housing in the inside back of the dryer. most just need a screw driver to open in, just remember to unplug the dryer before do any kind of electrical work...that includes changing a light bulb. unscrew the housing, make sure not to lose any of the screws. with the correct light bulb, just replace the burnt out one with a new working one.
Dec 25, 2014 | Refrigerators
How to remove the lamp
The bulbs are typically set in a small unit that disconnects from the insides via some kind of connector. The whole unit is then replaced.
Oct 24, 2014 | Acer P1265 DLP Projector
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 19, 2014 | Microwave Ovens
Magic Chef microwave MCO160UW stopped working after trying to change the lightbulb.
First thing to do is unplug it and take a pair of needle nose pliers and get the base of the old bulb out and replace it. Microwave ovens have a lot of things wired in 'series' which means that is one switch,bulb or any thing else in the circuit goes out then the circuit cannot complete it's path and will not let the other parts function. It is a safety feature that is built into them. As in many things I think they over do the safety features but they didn't ask me when they built it. LOL! Try replacing the bulb and let me know how it works.
Mar 15, 2014 | Microwave Ovens
How to replace other bulb in headlight assembly
what kind of car is this ?
sometimes like in FORD you have to remove the light housing to get to bulbs?
Sep 20, 2012 | 2003 Mazda MPV
Cavity light bulb out
Most of them are a appliance bulb like a christmas tree bulb. Google how to change it..
Feb 27, 2010 | Microwave Ovens
Do you have to replace the whole tail light assembly to replace a blown stop light in a 2005 Land Rover LR3? It saeems like you have to remove the whole assembly to get at the stop light?
No. reach in from inside, remove panel, tiset and pull out bulb and socket. The other kind have screws that remove from inside than entire lens pulls out to remove bulb and socket.
Sep 09, 2009 | 2005 Land Rover LR3
Burned out brake light. how do i gain access to bulb?
Inside your trunk there is a cover directly behind your lamp there are a few retainers that you need to remove then pull down the cover to reach the sockets that hold the bulb turn it to the left and pull it straight back then pull the bulb out to replace it.
the number on the bulb is what you need to know what kind of bulb to buy
Mar 13, 2009 | 2004 Nissan Altima
REPLACING TURN SIGNAL BULB
On the inside of the engine bay, right behind the headlight there should be some form of hand screwable, plastic holder for the bulbs, look for the one behind the indicator lamp, and screw it out, replace the bulb and refit. There may also be some kind of screwed on cover, which will need to be removed with a screwdriver. Hope that helps!
Mar 10, 2009 | 2002 Nissan Xterra
All bulbs new but still dont blink on right blinker
The falsher unit on these vehicles is a thermal one therefore if the amunt of bulbs in the circuit is reduced then the flash rate is alot slower, remove rear bulb, clean up the bulb holder and the contact inside the holder.
Good luck Davelee
Mar 04, 2009 | 1991 GMC Sonoma
Icom IC-R8500 Base Scanner Logo
62 people viewed this question
Top Icom Radio Communications Experts
Vincent G
Vincent G
Ngoro
ray gallant
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
