Question about Whirlwind FH-778 Air Conditioner
Good evening all, This morning woke up to my home
Good evening all, This morning woke up to my home freezing cold i'd left the ac on 72, cut it off allowed home to naturally warm up by the afternoon it was getting hot again so turned air back on and set it for 75, went to the store came back about an hour later to my house being very warm checked ac and it was blowing out warm air, cut it off and back on and let it run for a while still warm air. now it 3 hours later and air is blowing cool once again no frost on any of the lines everything looks as it normally does does anyone know what would cause it to work intermittingly??
Posted by Freda A on
  • Freda A Aug 31, 2013
    apprently i posted this in wrong section i live in a home with an hvac system not the whirlwind air cooler/heater and humidifier i see listed at the top of my question. Everything inside and out looks fine no frost and the unit outside is running just worried it may go out again at night
Brian Mills
    Master:
  • 613 Answers
Sounds like a faulty Tstat that's sending a low voltage signal to the contactor coil only sometimes. The high pressure cut out or the compressor's internal thermal protection could of opened, and then closed again after cooling. Make sure the condenser is clean and not obstructed.
Posted on Sep 01, 2013
3 Related Answers
Anonymous
  • 614 Answers
SOURCE: Our AC (Heat pump)is blowing hot air in the
Your unit may be going into a defrost cycle. If so sounds like a bad defrost board. It sends a signal to electric heaters inside to come on. Change board and sensor
Posted on Jul 28, 2009
Anonymous
  • 4 Answers
SOURCE: My A/C blows out hot air every couple days
The only problem I could think of is that the air conditioning needs to be recharged as they call it because over time it will run out. You can usually go to a place like Firestone and they will do it (depending on how much you need) for around 100 or you can find a way to do it yourself you would buy either R134A or Freeze 12 that might be harder to get but cheaper
Posted on Aug 19, 2009
SOURCE: my central ac unit started blowing hot air instead
Could be a number of things make sure the unit outside is running both fan and compressor.If not check breaker,stat,24 volt wires going to condensor they get hit with weed eaters a lot or just need cut and stripped and wire nuts replaced.
Posted on Jul 28, 2012
Coils freeze
Either your coil is blocked with paper or wrap, or you have a refrigerant leak in the coil and the little bit of gas that's left is flashing as it enters the coil. Make sure that the cooling coil and condenser is clear and the fans are running. That's all you can do without refrigeration tools. Good luck and hope this helps
Apr 22, 2014 | True Refrigerated Sandwich Prep Table 72"...
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
My central air AC unit (Double wide home) always works for generally up to two hours, then it freezes up, by the copper pipes ice over, shutting them off and letting them thaw out, works to get it going...
You are absolutely right! The copper pipes should have insulation them. When they don't and they get cold in hot weather, they sweat and then freeze. Tubular Foam Insulation is what you need. Most home centers carry it. Once you cut and install it, be sure to wrap it in a good quality Duct Tape.
Hope this helped you. Good luck.
Jul 15, 2011 | Coleman Heating & Cooling
The unit keeps freezing up solid even on energysaver
Change or clean the filter and clean both coils, no air flow or reduced air flow, the coil will freeze. It will also freeze if its set to cold 72 min. setting. Example if your room temp is 72 degrees, than the air will be 52, and the coil temp is 32 degrees, any moisture will freeze. Hope this helps
Jul 02, 2011 | Whirlpool Heating & Cooling
My thermostat is set on 72....but shows it is 76 in the house. I shut it off yesterday in case it was freezing up. 2 hours later, turned it back on and it cooled great the rest of the evening. I woke up...
it sounds as thought the coils on the unit need to be cleaned, make sure it is draining, if it still freezes up after cleaning coils and checking for draining then the unit has a leak and needs to fixed/charged. Hope this helps tim
Sep 12, 2010 | Heating & Cooling
AC freezes up after running two hours.
If it actually is freezing up,the low pressure switch is the likely cause.It is screwed into the large ac line near the firewall,witch is the cold line.If it is not there it is in the dryer,near the firewall,or under the air filter box.Follow the ac line(large ac line/hoses)from the ac compressor untill you come to the switch,that is the easy way to locate it.This low pressure switch causes the ac compressor to cycle on and odd according to the pressure sensed from the ac low side line.When it gets really cold the pressure is lowered,and there for it will cut off,and when the pressure rises,it cuts the ac compressor back on.It would be a really good idea to check the freon in the vehicle first.If the ac system is low on freon,it will freeze up on some vehicles.
Aug 25, 2009 | 2005 Chevrolet Equinox
AC blown warm air
This one is a difficult one to say. You could have a bad ac unit on the cars engine. Also when it goes back to 72 degrees your car is just displaying the temperature inside the car one of the features of a digital adjustments on these types of cars. Also you could have a leak and therefore not getting the cold air you wanted.
Jun 17, 2009 | 2000 Mercedes-Benz CLK
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Intertherm heater blows cold air.
do you have elec or gas heat? nat or propane?
Nov 16, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
89 people viewed this question
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Paul Carew
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
