HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
Anonymous Posted on Aug 31, 2013
Epson v500 scanner says "No scanner selected" message with Mac Desk OS X
Jeff Kerman
Level 2:
New Friend:
  • Expert 30 Answers
  • Posted on Aug 31, 2013
Jeff Kerman
Expert
Level 2:
New Friend:
Answers
30
Questions
0
Helped
8674
Points
107
Have you installed any Printer software for this epson v500 OfficeJet 8500 Printer or just connected it for the first time
2 Related Answers
JJTX77
  • Posted on Feb 02, 2008
SOURCE: Mac OS 10.5 Leopard
I was able to get my 6110 to scan by downloading HP_Installer_PSC7100_v9.7beta.dmg .  I saw this on XLR8YourMac for another HP multi-function and on a lark I decided to try it.  During the installer it won't detect the 6110, but you are able to "Skip" to the next step until it's installed.  Then, launch "HP All-in-One Device Chooser" and you will see the 6110 listed.  After I choose it there, I was able to use "HP Scan Pro" with the 6110.  I've not really tested the rest of the applications.
Anonymous
  • Posted on Jan 27, 2010
SOURCE: Scanner not found
same issue HP doesn't give support to its products properly, I discarded a scanner because HP stopped giving support to that unit. Now they don't support Scanjet 4850 working in mac os x. solution don't buy HP
Epson v500 Photo scanner was working but now gives a red light and whirring noise when opening the app installed on Mac - gives warning "cannot properly connect with scanner".
Here are some troubleshooting steps you can try for your Epson V500 Photo scanner: Check the connections: Ensure that your scanner is properly connected to your computer and turned on. Check the cables and ports for any damage or loose connections. Restart your computer: Sometimes, restarting your computer can fix communication issues between your scanner and computer. Reinstall the scanner software: Try uninstalling and reinstalling the scanner software on your computer. You can download the latest software from the Epson website. Check for updates: Make sure that your scanner software and computer operating system are up to date. Try a different USB port: Plug the scanner into a different USB port on your computer and see if it makes a difference. Reset the scanner: Turn off the scanner and unplug it from the power source. Wait a few minutes and then plug it back in and turn it on. If these steps don't resolve the issue, it's possible that there may be a hardware problem with the scanner that needs to be repaired.
The pdf button does not work
Make sure Epson Scan and the Epson Creativity Suite are installed correctly. See the Start Here sheet for instructions.
  • Make sure your Windows system is set up for scanner events as follows.
  • Windows Vista:
    Click sw_startbutton_1_er.gif > Control Panel > Hardware and Sound > Scanners and Cameras, or click sw_startbutton_1_er.gif > Control Panel and double-click the Scanners and Cameras icon. Click your scanner's icon, then click Properties. (When you see the User Account Control window, click Continue). Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows XP:
    Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras, or click Start > Control Panel and double-click the Scanners and Cameras icon. Then right-click your scanner's icon and select Properties. Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows 2000:
    Click Start > Settings > Control Panel, double-click the Scanners and Cameras icon, then select your scanner and click Properties. Click the Events tab in your scanner's Properties window and make sure the Disable device events check box is not checked. Also make sure the desired button is selected in the Scanner events list box, and the desired application is selected in the Send to this application list.
  • In Mac OS X, make sure you did not install the scanner software in Classic mode.
  • Epson Perfection V500 Photo Scanner
    Running Epson Scan Setup it says "Could not find files ..." Why?
    Hello maybe your current driver is vrong or corrupted.
    You can download the right driver from here:
    http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=88368&prodoid=63070478&infoType=Downloads&platform=All
    But you have to select your windows system 32 or 64 bit
    to make the scanner working.
    Uninstall the old driver before you install the new.
    Good luck
    I get 2/3rds of the way into installing the software and driver with the set-up disc that came with the Epson V500 Scanner, then a Error Pop Up message appears saying the following. Could Not Copy...
    Check that it is installing to the correct file. Normally C Drive "Program files" I would suggest you go to the control panel and locate and completely uninstall the Epson scanner program first. This will give you a clean install. Check that during the installation, the disc may ask where you want the program to be installed. If it has a suggestion, let it instal itself, where it thinks is best.
    4helpful
    I'm trying to install my new Epson Perfection V500 Photo Scanner. I followed the instructions. The software installed . When I turned on the switch a loud grinding noise occurred and t I get an...
    Its the lock mechanism under the lid , lift the top to the scan bed and look at the lower right hand side of the inside of the lid there is a grey swithch , move it to unlock! Voila , fixed.
    11helpful
    2answers
    Epson v500 not able to scan negatives! When I open uop the software, they don't even give me the option to scan negatives, just photos!
    You probably need to reset (not reload) the scanner software. Start the Epson scan software. Select professional mode from the pull down menu (it lets you choose between auto, home and professional.) On the next screen select at the very bottom select configuration. The next screen should have 4 tabs, select other. The at the bottom (I think) select restore to factory defaults. This will reset your software, now you can use auto mode if you want it to make all your selections or home if you want some control or professional if you want to control everything. Don't forget to use your film holder that came with the unit and remove the white cover that is locked underneath the lid that covers the film illumination bulb.
    2answers
    By using the epson v500 photo I get the following massage: "Please remove the document mat and/or close the document cover" Off course I remove the mat and de document cover is close. I send the scanner to...
    Possible driver issue. You have to reload the twain driver.
    To uninstall the twain driver, please follow the ff instructions:
    - Trash epson scan and epson scanner monitor from the harddrive
    - Go to the library, then application support. Trash epson scanner module.
    - Go to the library again, then image capture. Trash twain data sources.
    - Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
    Empty the trash and restart your mac.
    When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
    1helpful
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
