Question about Moultrie A5 Game Spy Low-Glow Infrared Digital Trail Camera 5 MP
Moultrie game camera flash will not work. All bulbs light up red but every night picture is so dark
Posted by Holly on
Anonymous
Try doing a hard reset, Turn camera off remove battery's and sd card. With everything out. Push on/off for about 5 sec. Put good battery's in ig. If you using cheap battery's make sure your are using Duracell or Engerzier battery's not rechargeable. Also make sure not using a micro sd card and nothing higher than a class 4 which is the speed of the card not the size. If still need help call with equipment to troubleshoot to Moultire 800653334 option 1 and 1 for a live person.
Posted on Mar 13, 2014
.Can not take pictures at night with my Moultrie 1100i trail cam. I was informed that there are numerous SD cards that should not be used.
Not being able to take pictures _at night_ likely has nothing to do with your SD card. If the SD card works during the day, it should be fine at night, too.
Any camera needs some light to take pictures. Many use flash to take night time pictures, or infra-red (IR) lighting. I don't know your camera well enough to know if you have either or how to configure how to turn that on.
Nov 11, 2015 | Max Electronics - Others
No night pictures
You cant see infrared flash, but it is not working. The only way to check this is with special equipment. If the unit is new, send it back.
Nov 18, 2013 | Moultrie Game Spy M80XT
Resetting the Moultrie A-5 Game Camera
HARD RESET TAKE OUT BATTERIES SD CARD PUSH THE ON OFF BUTTON FOR ABOUT 5 SECONDS LEFT EVERYTHING OUT FOR 2-5 MINUTES. THEN PUT THE BATTERY BACK IN TURN THE CAMERA ON IT SHOULD SAY NO CARD. THEN TURN IT OFF THEN PUT THE SD CARD BACK AND TRY IT IN THE DARK AREA TO SEE IF THE FLASH WILL GO OFF. IF THAT DOESN'T WORK WILL NEED TO SEND IT IN FOR REPAIRS.
Nov 07, 2013 | Moultrie A-5 Game Camera
My pictures at night are nothing but a black picture
HARD RESET TAKE OUT BATTERIES AND SD CARD, TURN IT TO THE ON POSITION FOR ABOUT 2-3 MINUTES WITH NOTHING IN IT. AFTER 2-3 MIN PUT BATTERIES BACK IN WHILE WITH THE ON POSITION IT SHOULD SAY NO CARD. ONCE IT SAYS THAT TURN OFF THE CAMERA PUT THE SD CARD BACK IN TURN THE CAMERA BACK ON AND TEST IN THE DARK. IF THAT DOESN'T WORK SEND IT IN FOR REPAIRS TO MOULTRIE.
Nov 07, 2013 | Moultrie Game Spy D-333 Game Camera
Won't take night pictures
Two possibles: either the IR flash is bad,or the day/night sensor is bad.Unless you have parts from another M80,best bet is to try Moultrie support and send it in. However, they may tell you to buy another camera.
Dec 28, 2011 | Moultrie M80 Game Spy Digital Hunting...
Moultrie D50 game trail camera won't take pictures in dark
Does the flash work? Could be flash circuit or day/night sensor.If you have another D40/D50 camera that flash works but has other problems,swap out the sensors.If not the sensor but the flash circuit then most likely one of the large charge capacitors which has to be soldered in.I use a digital multimeter with I/O capacitor test function..these caps should be about 250mfd.
Nov 21, 2011 | Moultrie MFHDGSD50 Game Spy Camera D50
All nite time pics are blacked out what can I do to fix it.
If the day time pictures are good then the setttings for the night shots must be selected according to the light intensity. Please check on the menu for night settings if you are intenting a low light shoot. Also make sure that the flash is active, in most of the present day samml cameras, the flash THROW is low and so the SUBJECT must not be too far as the picture will appear dark. So when using flash in a dark scene have the subject within 5-7 feet as the small flash will not be able to capture the openess. Also you can use a SLAVE flash to counter this and give a better prospective.
Sep 29, 2011 | Moultrie I-35 Digital Camera
Camera takes pictures at night but pictures are black it appears that the flash is not working
My Moultrie Came Camera takes pictures at night but they are just black, flash doesn't seem to be working, once in a while it will work, shows 18 pictures taken, only one came out. Batteries are showing 70%.
Dec 19, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie game camera won't flash
we get beutiful day pics, but totally black pics at night
Jan 26, 2009 | Moultrie MFH-DGS-200 Digital Camera
Moultrie A5 Game Spy Low-Glow Infrared Digital Trail Camera 5 MP Logo
1,511 people viewed this question
Top Moultrie Video Cameras Experts
Harrie
Andrew Taylor
Andrew Taylor
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
