Question about Intex "" Metal Frame Pool Set (56998e) 56998e
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Posted on Sep 01, 2013
Ditto to Bill's reply.
To answer your question... Don't get any Intex!
Look at Hayward, Pentair.
Posted on Apr 15, 2015
SOURCE: How do you install the adaptors part number 10722
You cannot use them unless you have a 1 1/2" female adapter for those to screw into.
Posted on Sep 05, 2009
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
Posted on Jun 17, 2010
Jul 23, 2015 | Intex Garden
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Jun 21, 2012 | Intex Krystal Clear Model 635 Pool Filter...
Sep 25, 2011 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
Jul 21, 2011 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
Aug 11, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Jun 16, 2010 | Intex 1000 Gallon Swimming Pool Filter...
May 20, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Mar 13, 2010 | Intex Krystal Clear Model 635 Pool Filter...
205 people viewed this question
