Hi If you are in the UK you can order via your local Maxi Cosi retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) RRP is 20GBP and if you order direct there is an additional 3.99GBP p+p charge. If you are not in the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab for your enquiry to be sent through to the customer care team in your country who can assist.
The combination has not been tested or been given the required safety certificates so we must advise that you do NOT use a Quinny Dreami on a Maxi Cosi Mura 3 chassis.
The Maxi Cosi Mura carrycot or 2013 Maxi Cosi Folding Carrycot ONLY should be used on the Mura for guaranteed safe combination.
The use of a Dreami on the Mura chassis has not been approved and we cannot accept liability for any malfunction of the product combination.
The handlebar foam of the Maxi Cosi Mura is not available as a seperate spare part item. To replace the foam would mean to replace the handlebar.
If you're in the UK and your Maxi Cosi Mura is under 2 years old please contact your retailer with your proof of purchase for them to make arrangements for it to be sent to our engineers for handlebar replacement.
If you're in the UK and your Maxi Cosi Mura is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to book in for chargeable replacement of the handlebar.
If you're not in the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab on the right side of the page to get in touch with the customer care team for your country.
Can you clarify - what button are you looking for?
The EasyFix base is fitted into the vehicle using the IsoFix points OR the 3 point seabelt. (Never both) The carseat then clicks onto the base and the metal rods on the underside of the CabrioFix carseat are grabbed by clamps on the base.
See if you can unscrew the handle bar first.
Then search for replacement foam online, maybe on ebay or bugaboo website. And when you have bought the replacement foam grips, you can take a look here to see how to attach them yourself.
html Bike grips and stroller handles work the same way. I just used this post on e-how to replace my maclaren triumph foam handles. Works like a charm - and it's sooo easy!! :)
Cables Broken In your Handle ???? Please visit Repairyabuggy.co.uk as we specialise in the repair of Quinny/Maxicosi Mura/My 3 -4 Handles,Grips-Cables Repaired
