You apparently are shooting in both jpg and raw modes. I do that. So what you have is actually two pictures. The jpg picture is full screen and the raw (nef) picture has the black lines you describe.
I don't know why it does this other than to allow you to recognize which pictures is raw and which is jpg. It is not a problem and picture quality is not impacted in any way.
Your manual should explain fairly clearly the benefits of both formats. You can use the menu to change it to take only jpg or nef pictures and possibly other formats.
When I edit photos, unless I'm in a hurry, I usually make a copy of the NEF photo and edit that. You can make many more changes in an NEF photo than you can in a jpg photo.
In either case, I would suggest you always edit from a copy to protect the original. I think my D-90 allows the use of other formats in addition to jpg, but nef is the only raw format that Nikon uses.
SOURCE: LCD blank & No picture taken
This appears to be a well known CCD problem, which Nikon acknowledges only for the COOLPIX 3100, 5700 and SQ models. Nikon denies the CCD problems on the 5400 are related, even though a Google search for this problem returns numerous results which claim the same defective Sony CCD sensor was used in the 5400 as was used in the 3100, 5700, and SQ models. See this reference: http://www.stevesforums.com/forums/view_topic.php?id=65777&forum_id=21
SOURCE: D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
SOURCE: Nikon E5700 digital camara.
There is a service advisory out for Nikon E5700.
t has come to our attention that in a
limited number of COOLPIX 3100, 3500, 4500, 5000, 5400, 5700 and SQ
digital cameras, an electronic component may, in some instances, fail
affecting your camera's performance and/or operability.
While only a limited number of COOLPIX 3100, 3500, 4500, 5000, 5400,
5700 and SQ digital cameras are affected by this advisory, if your
camera presents symptoms that can include (1) images with a strong
color tint, (2) images that are totally black and/or (3) images with
visible defects, Nikon will, upon confirmation that the problem is associated to this Service Advisory, service your camera free of charge.
link to info is here: http://www.nikonusa.com/Service-And-Support/Service-Advisories/index.page
SOURCE: problems taking pictures with nikon d40
Chances are good that it's not your camera, but your lens. In a darker atmosphere, you need a fast lens, meaning you need a lens that has a wide aperture (1.4 to 2.8) I'm guessing you're using a lens thats' 3.5 or larger. (Yes, the larger apertures have the smaller numbers)
If your camera was spending all it's time moving in and out trying to focus, it's probably because there was not enough light for the camera to distinguish a focal point. Same thing happens when you shoot a solid blue sky. No focal point.
Help me understand by telling me what lens you're using and what settings you were using on the camera.
SOURCE: My Nikon D200 digital camera will not focus when I depress the
Hard to pinpoint the exact problem...
What lens do you have attached? Does it have a switch for M/A and M (auto focus/manual focus)? If it does ensure the switch is in the M/A or Auto Focus position.
On the left side of the camera on the face there are 3 positions, C, S, and M. Ensure it is not on "M" for manual.
Do you have your camera setup to only allow the shutter to operate when it is in focus?
