Question about Northstar Pressure Washer 3000 PSI
Doesnt start - Northstar Pressure Washer 3000 PSI
I have a toyota camry 220sei it cranks bt doesnt start. When l push it,it starts. Bt when it starts the rev counter doesnt pass 2 and when it moves doesnt rev more than 2
On the diagnostic plug under the bonnet you can bridge out TE1 and E1 and read the fault code on the cluster if it gives any. Is it a 1993 to 1997 model.
Jun 16, 2016 | Toyota Camry Cars & Trucks
Wont start
Have you checked the coils
Mar 28, 2014 | 2004 Suzuki GS 500 F
1999 Dodge 1 ton won't start sometimes. There's no set pattern to it. Sometimes it'll crank right up, but other times ill have to try it everyday for a week before it'll start.
when it doesnt start does it crank? if it cranks all day and doesnt start spray some starting fluid in the throttle body and see if it starts and then if it dies then you are not getting enough fuel pressure but if it doesnt start then your iginiton system is acting up or your crankshaft sensor could be bad
Sep 13, 2013 | Dodge Ram Cars & Trucks
Gmc jimmy 1998 starting problem?
Most likely the antitheft. This link explains.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Apr 10, 2012 | GMC Jimmy Cars & Trucks
My dryer doesnt work. the tumbler doesnt turn. when you push the start button it sounds like its going to start but it doesnt move
hi check the belt maybe broken or if you just hear humming maybe motor. dose it heat at all? jim
Oct 11, 2010 | Maytag Dryers
Desktop doesnt start
may b your power supply is fail check Ur power supply. if that is OK it's mean Ur motherboard fault.
Feb 27, 2010 | Computers & Internet
Doesnt start doesnt even charge
its one of the problems related to the flex cable or nrw battery.
May 07, 2009 | T-Mobile Sidekick II
Car doesnt start
check your map sensor
May 02, 2009 | 1992 Honda Prelude
System Doesnt start automatically
Did u try restoring Ur BIOS to default settings............
that might help
if it doesnt pls do post back a reply
Oct 28, 2008 | Computers & Internet
Northstar Pressure Washer 3000 PSI Logo
20 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
