Question about Invacare Supply Group Invacare Pronto M51 Power Wheelchair - Blue - Power wheelchair
Will only work at a slow speed speed con worked fine the next day dead slow is al it will do
Posted by denney bryant on
ernest a fleming
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Have a dealer tech check it with a programer and he will tell u what the problem is by checking the error log could be just a joy stick needs to be reset or the control box in the rear,make sure your insurance will help with repair
Posted on Jan 20, 2014
My 05 Focus speedometer is wacky. All other gauges and systems work fine. The speedometer needle doesn't go to zero when vehicle stops moving.
Sounds like the speedometer is faulty. If the speed sensor were the problem, the odometer would not work correctly, the transmission would not shift correctly, and the check engine light would be on.
Nov 28, 2015 | Cars & Trucks
Will only work at a slow speed speed was working fine then next day dead slow is all it will do
I had a same problem but worked fine when I installed mackeper. Its easy to remove errors you may have which slowed it. Try it out and let us know the outcome. Here is the download link to it. Good Luck http://bit.ly/1aHCD0n
Aug 31, 2013 | Pride Jazzy 1113 Power Chair
Battery keeps going flat
Check alternator voltage output, might be low. obd2 scanner
Jun 12, 2013 | Cars & Trucks
My 2002 Mercury Sables gives a "bucking" sensation
Yes Brother, I know that experience. Have a computer test done to find which cylinder is misfiring and replace that fuel injector. It's gone dead and we call this a dead cylinder. Seems like it runs fine, until you hit overdrive. Then it feels like you're running on one square wheel. A steady thump.
Nov 12, 2017 | 2002 Mercury Sable
A 303 cassette deck - the belt has been changed. The feed spool and capstan turn fine. The take up spool does not turn and play stops after 5 sec. Take up spool is fine in fast forward. Help !
This is a case of a failing reel motor. What happens i sthe brushes become aged and wear down and the motor has what they call a dead spot on the Commutator. The motor will work fine at high speeds as the inertia is working for it but when you use a slow speed as in play mode the motor hits the dead spot and stops. You will need a new reel motor in the most likely case- I can service the deck if you want at Skywave Tape Deck Repair Chicago area. I will most likely put a new motor into the deck.
Oct 04, 2010 | Teac V377 Single Dual Cassette Deck
Fujitsu Reverse air con not blowing heat anymore
Reverse setting could need checking here sliding valve could have siezed. you would need a service Technition. your default setting is working fine so it needs to be checked on heating mode function.
Jun 09, 2009 | Heating & Cooling
Slow speed
Check TPS (throttle position sensor located on throttle body) TPS controls 0-60 speed if the spring inside is broke it will not work right.( make work one day and not the next)
Apr 23, 2009 | Peugeot Liberte Cars & Trucks
USB transfer speed is low
THERE WILL BE A DATA TRANSFER RATE PROBLEM IN YOUR LAPTOP ONE OF THE USB PORT.TRY IT ON ANOTHER PORT .IF THAT DIDNT WORK I SUGGEST THE BEST THING TO DO IS TO CONSULT WITH A CERTIFIED TECHNICIAN IN YOUR AREA.IT MIGHT BE A HARDWaRE PROBLEM.IF U FIND THIS SOLUTION USEFUL PLZ RATE IT.
THNXX
Apr 03, 2009 | Acer Aspire 5610-4648 Notebook
My jvc AL-A151 spins records too slow but gets better
I had this problem. In my case it manifested itself mostly in start-up, and I found that I had to move the tonearm past the 1st track to get the TT to spin. I cleaned the contacts on the micro-switch (on the mechanism, from below) with extra-fine sandpaper. It worked.
Nov 21, 2008 | Audio Players & Recorders
Open Questions:
See all Invacare Supply Group Invacare Pronto M51 Power Questions
Invacare Supply Group Invacare Pronto M51 Power Wheelchair - Blue - Power wheelchair Logo
85 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Lawrence Oravetz
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
