Question about Lanier Audio Players & Recorders
I need a manual for a lanier p-135 voice recorder
Posted by Darrell Goodwin on
3 Related Answers
KtsBeenGone
SOURCE: I need a user manual for the Lanier P165 Voice recorder
I need a manual, too; however, I may be able to take an educated guess at some of your problems.
To get it to work (after trouble-shooting for battery issues, etc.), you simply slide the long "button" up and down. There are four settings -- all the way up is "record," then under that is "stop," then "play," and finally at the bottom is "rewind," which it does audibly. The two buttons beneath that are FF and eject (just below FF).
On the other side, there are four switches -- The top one adjusts microphone sensitivity from dictate to conference, the next one is tape speed (higher number means better quality but shorter time on tape), then the VOR on/off switch (voice-operated recording) which would start and stop the recording as you speak into it. Then below those three is simply the "on/off" switch for the whole recorder, so it doesn't accidentally get turned on in your pocket and you unintentionally record something.
On the top appear to be a few input jacks, one for a mic I guess and maybe other is for a speaker or headphones? Then there's the mystery button, that is labeled something like "# | / AFF." I have no idea what it does, but it may be to assign your counter number (counter and reset button on the front face of the machine) to a specific tape, so you can change tapes and return later to your first tape again without losing your place. Just a guess.
Here's some info I found on a seller's website - it served as the basis for some of my guesses above: http://www.martelelectronics.com/p165lp.html.
Posted on Jun 11, 2008
tscmusa
Mitch Davis
  • 95 Answers
SOURCE: Is a manual available for the Lanier MS-60
I havent found one,but it appears simple enough to operate.Martel doesnt sell this unit anymore and i havent seen any I Manuals on the web.Looks like a quality unit though
Posted on Apr 28, 2010
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: RP5010 Handheld Digital Voice Recorder: need a manual for 5010 digital recorder...
You can download the complete instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on May 24, 2010
You can not tell me what setting to use on LANIER P-165 so that i can record someone and how far from them
If you want to record somebody 3-4 feet from you then use the dictate mode. If you want to pick up voices in a large room then use the conference mode, it increases the microphone sensitivity to the maximum level.
Jul 01, 2013 | Lanier P165 Handheld Cassette Voice...
Apr 26, 2010 | Lanier P160 Handheld Cassette Voice...
User guide Lanier MS-56 micro recorder
Itrizuto: Did you ever figure this out? I have the same question.
Aug 24, 2009 | Lanier Audio Players & Recorders
HELP!!!!
The only people I know that can still fix old Lanier machines are [email protected].
They are trained on Lanier and worked there for many years.
Dec 05, 2008 | Lanier P160 Handheld Cassette Voice...
Lanier VW-260 recording speed
Should be a tape speed switch on that unit under the door.
May 23, 2008 | Lanier 260T Desktop Cassette Voice...
Lanier VW110 won't play
yes I have two lanier voice recorders one left hand and one right hand one power supply real cheap do not use them any more . listed on ebay as lanier vw-110 standard cassette dictator. If you still need them. Thank you John
Jan 10, 2008 | Lanier Audio Players & Recorders
122 people viewed this question
Top Lanier Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
