Find out, where the Fuses are ? if outer power source is okay,some fuses are hidden under some cover or inside the box .Replace fuse with the same value if found burnt.
Make a note of how the belt fits, then remove it and measure the diameter. Then buy a replacement, belts do go bad from time to time, so a new one might cure the problem. Put the diameter size (to the nearest mm result, IE: 50 or 55mm, not 52mm! Into google and "cassette belt" and you should find one for the job.
