Question about Cuisinart DLC-8S Pro Custom Food Processor
Kitchenaid kfp715wh2 won't run - Cuisinart DLC-8S Pro Custom Food Processor
KFP0711 Kitchenaid food processor won’t turn on even when put together. Just opened and never been used.
Read the handbook and make certain you are assembling the bowl, lid and pusher correctly, they can all play a part in activating the safety mechanisms that put the appliance in the mode that will allow it to be started.
Nov 24, 2017 | KitchenAid Food Processors
I've a KitchenAid Artisan 4L Food Processor. Closing the lid of the bowl does not activate the motor. I can surpress the black mechanism with a knife and then the motor runs. Please help?
The problem will be either the lid or the bowl, both have mechanisms in them that wear/break. Take the processor into a service agent that carries the parts along with your clean bowl and lid. It will be a simple matter for them to try one or the other to see which one makes the difference. I am a service agent and that's what I do, it's far the easiest way to quickly find the problem.
Mar 29, 2017 | KitchenAid Food Processors
Very frustrated with kitchenaid food processor - using any slicing disk only the first batch of food works, when you put in the 2nd batch nothing happens
Mine is older and works fine once I realized bowl has to be snapped into place before the cover and then the cover has to be locked in. This activates a small button at the base of the bowl that activates a safety switch.
Jan 03, 2015 | KitchenAid Food Processors
Kitchenaid kfc 3100
Probably the mechanisms in either the bowl or the parts of the lid that engage the bowl mechanisms.
Aug 31, 2012 | KitchenAid Chefs Chopper KFC3100 3 Cups...
My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Dec 20, 2011 | KitchenAid Food Processors
Kitchenaid mo.kfc3200082
hello. here is the link to the kitchenaid manuals
http://www.kitchenaid.com/flash.cmd?/#/page/customer-service
this is a free download.
kindly rate my answer as helpful. thanks, joe
Feb 22, 2010 | KitchenAid KFC3100 Chef's Chopper Food...
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
How do i print manual
Manuals for Kitchenaid appliances may all be downloaded and printed from Kitchenaid.com.
On the main page, click "Customer Care" in the upper-right hand corner. Then click "Locate Manuals and Guides."
You will need to enter your model number exactly as it appears on the bottom of the appliance. You should find the model number on a white sticker.
Feb 07, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
Cuisinart DLC-8S Pro Custom Food Processor Logo
Top Cuisinart Food Processors Experts
eyecam
ADMIN Canada
ADMIN Canada
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
