PDF
BaoFeng BF-888S ... Lights red during transmit, green when receiving a signal ... you that battery needs recharging. Alert tone will sound and Red LED will blink.
7 pages
The CLS has preprogrammed frequencies. The Bao can be user programmed. If both are Uhf, the Bao must match the CLS unless one of the CLS frequencies is already in use in the Bao. So, are you already using CLS and adding radios? You need the actual frequency and tone code. If you do not understand, contact a dealer like us, local is even better! Channel 1 is only an indicator, not a frequency. [email protected]
1. Make sure both radios are transmitting and receiving on the same frequency (no repeater offset).
2. Either turn off CTCSS tone or make sure both radios are set to the same tone on both Tx and Rx.
The usual problem is an incorrect driver for the usb/serial chip in the connecting cable. Windows installs the latest driver but clone chips need an older version. There's good advice on these pages:
If you are using Win7, there is a problem with the USB-Serial driver. Look at www.miklor.com for how to install drivers and other Baofeng info.
JohnW
W5JHW
