Question about Philips 42PF9966 42 in. HD-Ready Plasma Television
42PF9966/10 - PHILIPS - UNIT NOT WORKING, NO PICTURE, PWR OK
42PF9966/10 - PHILIPS - UNIT WAS WORKING NOW A BLANK SCREEN WITH ONLY A FLASHING RED LIGHT. ANY IDEAS HOW TO GET THE TV WORKING.
Posted by scragg_neil on
doc2r
    New Friend:
Having the same tv and problem for a year ago.
I disconnect the main powercord from wall socket
and wait for 2 min. and connect again.
Problem solved. Its not a fix, but maybe it helps?
Posted on Nov 07, 2009
Anonymous
This sounds like the power supply. I had the same thing happen to mine just before xmas. It was an $800 repair! Now my Y sustain board is gone and can't get parts. This tv is a dud!
Posted on May 20, 2009
Christy
    New Friend:
Hi all I have 42PF9966/10 ambit light when I turn on tv red light flashes I read check capacitors and I did but none blown or leaking can anybody tell me the which one's to change, I saw other people said that 3300uF 10v 105c were the one's to change but not in this model
Posted on Jan 01, 2013
Philips instruction manual
YOU NEED TO REPLACE BAD CAPS ON MAIN POWER BOARD 4167e67a-4c77-4574-ae00-a26d52afd0ea.jpg
Jul 29, 2014 | Philips 42PF5520 42 in. EDTV-Ready Plasma...
Red light flashes blank screen
I have the same problem on 2 of my IP's - did you manage to sort it out?
Mar 27, 2013 | Saitek Pro Flight Instrument Panel...
Nec pf-68v21 pwr led flashing red green after horizontal output
check the supply at horizontal driver trans former ,if voltage is correct at ho/driver trasistor ...then check allthe fusible resistances from power supply,,,if tv is taking h/oscillation for awhile ,,give more screen control in lot,,, & see for a horizontal line ,,,before tv becomes off,,, if so vertical ic problem...
Mar 16, 2010 | Televison & Video
My Philips standard tv picture went out
You may have a corrupt eeprom! Eventually the red light will come on with no audio or video!
Jun 17, 2009 | Philips 27MS4504 TV
17" Philips LCD TV has sound, faint blue flashes and blinking pwr
GP151001, Typically these cable/wire connectors fall into a catagory called HIGH DENSITY INTERCONNECT connectors or similar type. I should think that the whole assembly should be available somewhere ****!!! It's just this kind of thing that really gets me P.O.ed louie12fix
Apr 15, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
No pwr
the flashing red light is caused by a burst or bulging capacitor on the power supply side of the dvp642's mainboard.
to fix it simply dis-assemble the unit removing the mainboard totally from the casing. search for the bad capacitor on the main board. once you have found it simply turn the board over and using a soldering iron and some desolder twine desolder the capacitor from the board being careful not to burn the circuit board or lift any traces.once you have removed the old capacitor take it and purchase a replacement from radioshack or equivalent store. make sure the replacement has the exact same voltage rating and AT LEAST THE SAME AMPERAGE higher is ok lower will not work.but the voltage must be exactly the same. resolder the new capacitor to the mainboard and reassemble and viola your up and running again
Mar 29, 2009 | Philips DVP642 DVD Player
Philips 60p8342 chassy ptv 916
check all your solder connection and test the resistors on the conversion IC's , also check oscilating circuts
Oct 27, 2008 | Philips 60P8341 60" Rear Projection...
Canon EOS 1000F in-built flash unit
Set camera body for Internal Flash for Pop-Up Flash.
Set camera body for External Flash for parked flash on Hot Shoe.
[email protected]
Nov 08, 2007 | Canon EOS-3 35mm SLR Camera
Philips 42PF9966 42 in. HD-Ready Plasma Television Logo
1,220 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
