The puk code is a code associated to SIM card , not to the phone.
You have to choices, call the phone company or replace the SIM card inside.
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the PUK code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
SOURCE: nokia e 65 puk code
The PUK code is actually shoing up because you hard locked your sim card - you didn't enter the SIM password correctly 3 times.
You will need to contact your proveder for the PUK
SOURCE: PIN CODE IS LOCKED REQUSTING PUK CODE
Hi
You have to call your telephone service provider so that they can generate the PUK code for your phone to unblock it.
Thanks for using Fixya
SOURCE: can't remember phone lock code
Puk code is needed when you have entered the pin code wrong 3 times.
If you have a phone lock code on it and you can't remember to code try the defaults 0000 1234 12345 00000 etc. if you can't unlock it contact your dealer with proof or pruchase or contact a samsung service center, you can get those details from www.samsung.com you will most likely have to send the phone to be unlocked.
you can try entering these two codes without a sim card in the phone. write them where you would write 911 phone should restart. then insert the sim card and try turning the phone on.
*2767*3855# = Full Reset
*2767*2878# = Custom Reset
If these don't help then contact samsung for unlock service you will most likely have to send the phone to a service center.
SOURCE: phone is locked and asking for a PUK Code. Says
HI If you are asking for pin contact your service provider , he will give you a default pin . If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
SOURCE: puk code
