Sony STR-DE525 Logo
Question about Sony STR-DE525
SONY STR DE 525 STERO RECIEVER HAS PROTECTION LIT
I FOUND R 552 AND R577 BURNED PLUS Q 558 TRANSISTER SHORTED. WOULD LIKE TO HAVE VALUES OF RESISTORS AND WHERE I COULD PURCHASE ALL.THANKS ED PACE
  • Anonymous Apr 23, 2009
    THANKS A MILLION---ED
Michel Dandurand
  • 14 Answers
Q558 = 2SA988A
R552 = 120K
R577 = 6K2
voilà!
Posted on Apr 23, 2009
2answers
What could be a cause of my sony trinitron 21''crt tv it's problem is fuse burned and STR is shorted when i change it it burned and shorted again ?
If STR is found damaged, you should check all the assciated components with it; like resistors, zener diodes etc: before replacing a new STR. All such components should be checked individually [out from the circuit]. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Can not get surround sound to work
Your Protection System probaly come on for some reason,Sony Is Known for that problem, Check on your screen if a red lit warning Staying (protect) Is on.If there is, Try hiting the reciever on the sides or the top of the cover fairly hard when it is turned on, Some times this will work to turn the protect light back off, Sony is bad for there amps end recievers going into the protect mode,
Hi. my sony STR-DE 597 go in protect mode. how can I fix/repair this? Give me a tips.
protect mode means there is a shorted components inside your reciever it's probably the out put transistors take out the transistors and test it with a multimeter.
PROTECT shows every time I turn my reciever on. It's a SONY model #STR-DE335
Turn it OFF. Look for shorted speaker wires or shorted speakers.
None found? Disconnect all speaker wires and try to turn it on.
Turns on ok? One of the speakers/cable pairs is shorted. Check them again.
No good? It's dead. take it to a tech.
http://www.retrevo.com/support/Sony-STR-DE335-Receivers-manual/id/387bh942/t/2/
1helpful
The word Protected shows up on the reciever! I tried to clean out the bad grease on the Volume control. The remote got so sluggfsh it would hardly move.
Protected is usually the unit has partially shut down to prevent further damage or burning up. The high power amplifier section is shorted or the speaker wires are shorting, including speakers. The speaker wires can be checked and eliminated as a problem, where frayed wires are touching the other terminal or a bad shorted speaker. If all external short have been eliminated, a technician would have to fix internal short.
3helpful
Sony STR-D715 Protect Mode
This is a common problem...
It is in fact a bad power-amp module.
I have repaired quite a few of these receivers by replacing it.
The module is inexpensive. I Googled the Part number and found several sources for it.
2helpful
Sony STR DE 197 Reciever with No Sound
I have the same unit. My best recommendation would be to remove all speaker wiring, and try new wiring with another pr of speakers,since the "outdoor " speakers were rained on. the protect mode that the unit went into sounds like it did because the speaker outputs were shorted due to the rain, so ensure that the speaker output terminals are not shorted and dry...also see if output is still availalable at the headphone jack...if it is, the pre-amp section is still good , in which case the protect mode and no volume output out of the speaker jacks may mean that youve blown the ouput trasnsistor finals.
I hope this helps.
bobbymaximus
Sony DE-445 reciever flashes PROTECT
Sounds like a grounding problem. If the ground plug isn't missing or loose try plugging it into a different outlet.
3helpful
2answers
My reciever does not work
Power Amp IC gone in your set, replace it.
Help
check/replace your speaker wires. If a wire came loose, it will go into "protect" mode and shut down, to protect from a short circuit.
Top Sony Audio Players & Recorders Experts
Marvin
Marvin
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
