SOURCE: North Star DX 330 HML has no receive
Radio dude, we'll try to help with the problem your having with your Northstar base. I assume you have checked all the controls to make sure they are functioning correctly? ok, based on what I'm reading for the problem, I'd say your looking at a bad solder joint on the main circuit board, or a close powerful station might have keyed up and blowed the front end out of your receive. There are 1 or 2 fet transistors in the RX chain and with the age of the radio, one of those going bad on it's own is a possibility. Sounds like it needs some hands on troubleshooting, are you electronically able to work on it?? Hope this helps in your search and let us know,, Mechanic
SOURCE: refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
SOURCE: 10 kc drop at key up no transmit
have you changed the voltage regulaor, or check it first 2 outside legs should red your 13 volt middle around 9
SOURCE: power meter on my dx-979 barely moves off of 0
Well,some meters are set different than others,to see what is going on,you need a good WATT-SWR meter,but that is not a bad reading of SWR, you can get one at Radio Shack. You can not go by the meter that is on the radio,it,s probably not set right. hope this helps..
SOURCE: galaxy 44v no transmit or receive
Try replacing TR41 (2SA473).
Also check TR40 (2SC945), D78 (7.5 volt Zener Diode), and D79 (KB 262).
[email protected]
