Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Posted on Apr 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ghost shadows on the Sony KP-46WT500TV
There is a ghost shadow of red on the screen. The alignment button shows not all colors are aligned. How do align I them?
Sonny Berry
Level 3:
  • Sony Master 8,617 Answers
  • Posted on Apr 12, 2009
Sonny Berry
Sony Master
Level 3:
Answers
8617
Questions
Helped
1722989
Points
23750
You can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
http://servicemanuals.vstore.ca/
Red tube wont align,red ghost shadows on the picture
hi,
check the red guns crt base socket . may be it have some problem. when u change the crt base try to change all the three guns base socket.
ok
2answers
Blurry picture. Red & green ghost. I am currently removing the circut board to replace the amplifiers. How do I remove the high voltage wire from y=the transformer
Not any amplifiers problems.The problem u having it known as covergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors pictures shadows or 3D look like pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the convergence board to solved the picture convergence problems.The Shop,will cost u $300-350 for parts and labors.
My Sony KP-51HW40 shows a redish shadow behind the objects in the picture. Is this fixable? thank you ! John
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
How can i line the lights up in my sony kp-61hs10.
I'm going to assume that the "lights" are images on the screen that seem to have a multi colored shadow. Within the menu there's a choice for convergence, when selected this gives a white cross centered in the screen. Using the arrow keys on the remote (left-right for vertical movement and up/down for horizontal) you will adjust the color that is "shadowing" or get all the colors aligned so the white cross has no trailing red or blue either horizontally or vertically. If you can't get it to adjust or there is no effect then repair is probably the only option.
1helpful
Shadow
The sony convergence Kit Type 1 available at the following link will usually repair that issue. The kit contains the parts plus a CD with detailed instructions to do the repair.
www.tvrepairkits.net
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Sony kp-48s75, shadow or ghosting picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Getting Ghosts and color line separation.
my sony kp-57wv600 is showing a ghost of the image in all three colors.. anyone no how i can fix
Sony KP-51WS500
the tv needs to have a convergence done on it to realign the picture..the colors have to be set a certain way or it will show shadows and it will only get worse
Sony kp-46wt500 problem with picture
i'm having a problem keeping the timer from going off and shutting the whole tv off.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
