Sanyo DS24424 24" TV Logo
Posted on Sep 10, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WILL NOT POWER ON
POWER SWITCH ON THE SET I HEARD A KLICK SOUND {RELAY} AND A COUPLE OF SECOND I HEAR A CLICK SOUND AGAIN.I TRY TO MEASURE B SUPPLY THERES 130VOLTS WHEN FIRST CLICK OF THE RELAY AND THEN DROPS TO 80VOLTS ON THE SECOND CLICK OF RELAY. I SUSPECT THE FAULT COME FROM IC LA76952DC.
  • 2 more comments
  • bb54 Sep 23, 2007
    Thanks Modern. I already isolate the Hor section {output}but still got the same problem. Could u please provide me the circuit discription of the IC LA76952DC {jungle IC} I dont have schematic diagram of this TV set. Again thanks.
  • Noahh Jun 15, 2008
    Same problem here. It clicks on, stays on for about 2 seconds (with no video), then clicks off. I can make it do that twice and then nothing. I have to unplug and then plug back in for it to do it again. Is it worth the repair?
  • Anonymous Sep 16, 2008
    Same exact problem.
  • SeaCapt Oct 19, 2008
    Same problem, tv clicks, hear sound for about 2 seconds, another click and shuts down, no sparks no smoke no video.
Anonymous
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 556 Answers
  • Posted on Sep 23, 2007
Anonymous
Expert
Level 2:
Prodigy:
Answers
556
Questions
0
Helped
173154
Points
916
Isolate power from hor.output section. if voltage becomes normal 130v &it does not drop then power supply is ok. now check hor output for leaky compnents near eht specially capacitor & diode. check hor output tr. at last eht. you can clean print near eht.
  • 1 more comment
  • Anonymous Sep 23, 2007
    as you have isolated h/output but the problem still persists(voltage is dropping) means 100% now it is clear that problem in power supply only.
    please check
    1 cap or zener in switching reg. line.
    2 one diode might be open in bridge rec. ckt
    3 if set is old main filter cap dry.
    4 low input supply.
    As per circuit discription of the IC LA76952DC {jungle IC} schematic diagram of this TV set not required as it is a jungle ic & our problem in p/supply.
    but i assure that i will send data with in day or two.
    good luck
    please refer web site
    www.datesheetcatalog.com
    it is a SANYO make so check in SANYO DATA.
3helpful
2answers
I heard small pop then lost power while watching my lg 50pg20. No red or blue lights on the power switch. What could be wrong?
you are describing a power supply defect. IT may be as simple as the main fuse. I believe the one in this set is a 6.5 amp located on the ps board right by cord connection. IF after replacing the fuse opens a second time you will need to replace the power board.
p[lease leave feedback
3helpful
4answers
It wont turn on
You give us littel to go on here. Can you describe what happens (if anything) when you attempt to turn on the set? Is there a click? Is there a standby light on the set before you try turning it on? Is there sound or nothing at all?
While possible, dead sets are not usually caused by a blown fuse. If the fuse is blown, then the power supply will need work. If not blown, the power supply may still be the problem. Please update this with any other symptoms and we'll try to assist further.
Thanks,
Dan
2answers
1998 tl 3.2 won't start. only a 'tak' sound can be heard
it culd be problem with solinoied switch of starter, or with ignation switch, to find out, when car wont start some one have to check supply at starer solinoid small nut mounted wire, if supply is there then you can go to check if any relay is there before ignation switch if relay is fine you can replace ignation switch.
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
PC won't start
Hi, you're not supposed to hear any clicks as there are no relays in a normal pc. I'd suggest try a different power supply, also try to see if it starts up when the hard drive is disconnected.
1helpful
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
1helpful
Toshiba cf32c50 tv will not turn on
This is a typical condition if the power supply has failed or a power-consuming circuit the supply services has exceeded a predetermined current draw. The relay you hear is preventing further damage or even fire.
You will need local tech help with this.
1helpful
Sanyo DP32746 Power Supply
Yes replace the power section of the tv.
Power supply of tv
if voltage drops means there is a short circuit in your tv. 1 disconnecting 120v line if supply becomes ok then there is short ckt in horz.section &if it does not gives 120 volts then there is problem in power supply. please check as per instruction &let me know. good luck.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
