Brother Multi-Function Center  MFC-3360c All-In-One InkJet Printer Logo
Posted on Sep 10, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error when switched on shows please wait
Anonymous
Level 3:
  • Master 832 Answers
  • Posted on Dec 23, 2007
Anonymous
Master
Level 3:
Answers
832
Questions
0
Helped
558452
Points
2204
Unplug machine from power outlet and replug. Is it still coming up`?
My wa13v9 washing machine is showing DE error code but the lid is close and draining pipe is not blocked
https://www.youtube.com/watch?v=Vse_sK8LPXc
Samsung top-load washer error codes
  • 1E. Water level sensor failure. Check/ ...
  • 3E. Drive motor or hall sensor (tachometer) error. ...
  • nF or nF1. Water supply error. ...
  • nD. Won't drain. ...
  • AE. Communication error between the main electronic control board and the display control in the control panel. ...
  • E2. Stuck button. ...
  • DS, FL or LO. Lid lock/switch failure. ...
  • HE1. Heating element failure.
https://www.searspartsdirect.com/diy/error-codes/washer-repair/1234598/samsung-top-load-washer/1482
Switch off the power to the appliance, wait 30 seconds then Switch the power supply back on. The drain pump should operate to drain the washing machine. If problem persists please call the customer support team. Switch off the appliance at the mains then wait 30 seconds.May 22, 2019
https://www.samsung.com/levant/support/home-appliances/washing-machine-what-does-the-error-code-means-and-how-to-fix-it/
1helpful
Error 6a81
Turn off power, remove power cord and wait 10 minutes, then reconnect power cord and turn unit on, if this does not work then advised to contact canon service centre
5helpful
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
10helpful
3answers
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
1helpful
How di I reset my Pixma printer MP150 from
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full
First way
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
Second Way
turn off printer.
Good Luck
My car audio got blocked.The display is showing error message as i tried several times to unblocked it unsuccessfully. But now i got the original code from the Renault dealer but i cannot enter it as the...
To restore from ERROR  leave your radio SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
It may take several hours as the waiting time doubles after each wrong code
My machine show c 210
Please specify the machine model,in the Ricoh 1035 not exist the C210 error code.
If your machine show CC201=When the paper jam condition is not reset for 10 minutes the code is automatically generated.For reset please enter in the SP mode turn main switch OFF,unplugged and wait 10 sec.Plugged and turn ON the power switch.
25helpful
3answers
Brother MFC-210C stuck in "please wait maintenance"
Press menu then start mono (b/w) then 4x arrow-up-button. Machine will be in maintenance-mode: What error code does the display show off?
Norman Weimar
Norman Weimar
k24674
