CD/burner is gone and Wont load anything i put in.
I recently got my pc back from the shop. and was trying to install my mother board drivers via the cd. I browsed the cd and tried installing a sound component, when all of a sudden the blue screen came up saying windows shut down to prevent a problem.
I start back up and my cd burner is no longer in the My Computer menu. Nor can I use the cd rom/burner to load anything. I can open and close it. but nothing.
I see many sites including this one. with a fix where you delete the lower or upper filters from the registry. But with my pc these ''Upper'' and ''Lowerfilters'' are not there. How can i get them back or. what can i do to get my cd rom working again?
Im running windows xp service pack 3....Apparently.
Posted by japmaicanese on
  • 7 more comments
  • japmaicanese Apr 12, 2009
    Ive done that about 3 times. all that happens is; it starts up without me getting any huge error or anything, but when i check the My Computer. the Rom drive is till not there. and in the device manager the exclamation mark is still there.
    Double clicked the Exclamation mark. or..device rather.. and theres this msg in the General tab
    "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
    Click Troubleshoot to start the troubleshooter for this device."
    As for the event viewer I do see some exclamation marks for certain things asking me to enable IPs, but one big error sign for something i had previously tried from the Microsoft site. where it told me that the "fix it" program does not work for my system. its referring to the "Delete upper and lower filters from the registry"
    This is an exact screen of the folder. The Microsoft support site said if i dont see them in there it couldnt help me. So heres hoping i can get some help here. (i hope that thing can be zoomed into)
    Edit. no..why does this thing make it non zoomable?.. anyways. heres a link. to the image. (imageshack)http://img113.imageshack.us/img113/1959/...
    Sorry, Delete the what? Aforementioned key? where do I find that? Is there another name for this?
    Is that the. {4D36E965-E325-11CE-BFC1-0800..etc entire folder?
    Okai. If i did like you asked. Deleting what was inside that folder. Northing has changed after restart; and the rom drive is still missing.
    Contents. Windows wouldn't let me delete folder.
    Did it try to reinstall it? no. The device is not inside the device manager, but still says the same error it did before when i try and run the hardware wiz. "Cannot load device driver it may be corrupt or missing"
    notes: I tried a program called Driver detective and apparently the driver is up to date for the rom. (just thought that might be useful info)
    Well now the computer doesn't seem to recognize the rom at all or boots from it. not sure i can reininstall windows now.
    A lost cause I take it. Alright. Thank you for your help thus far.
Arthur Hoffmann
  • 227 Answers
Try using device manager and deleting the CD from it, then reboot and let windows do its thing with intalling it again. Let me know if windows does NOT try to reinstall the CD drive or you get any error messages
Posted on Apr 12, 2009
  • 6 more comments
  • Arthur Hoffmann
    Arthur Hoffmann Apr 12, 2009
    Double click the Exclamation mark and post the results, use a screen capture if possible
  • Arthur Hoffmann
    If you use Event Viewer under Administrator Tools from the Start menu under Accessories,Do you see a message similar to "The following boot-start or system-start driver(s) failed to load:
    aha154x"
  • Arthur Hoffmann
    are you sure you went to the correct key in the reg. I looked at mine and there are several that are close with most of the same entries, but do not have upper and lower, when I found the exact one it had upper and lower, verify 100% you went to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    the bold section is VERY IMPORTANT
  • Arthur Hoffmann
    OK lets try one more thing, then I will need to reseach this a little further. Go into the reg and totally delete the aforementioned reg key. Then reboot. See what happens. Let me know.
  • Arthur Hoffmann
    I was able to zoom it in my browser.
  • Arthur Hoffmann
    aforementioned key (the reg key I Mentioned Before)
  • Arthur Hoffmann
    Just the {4D36E965-E325-11CE-BFC1-08002BE10318}
  • Arthur Hoffmann
    Did you delete the folder or the contents only? Did windows try to install the driver?
I dont have mother cd with me and i need to install the mother board cd in my computer becoz display are not working properly
Your board has Socket 754, VIA K8m800 and KIA VT8237 chipsets With Realtek sound. S3 Graphics Unichrome. This is Gigabytes link to downloads. I ahve entered your info but will outline for you.;
http://www.gigabyte.us/support-downloads/download-center.aspx
Option 1
1 Select Product catagory Motherboard
2 By socket- socket 754
3 By chipset-VIA K8M800
4 Model Name- GA K8VM800M
Click search
New screen, scroll down and enter o/s
Drivers will show up Scroll down to VGA Driver and pick
"VIA K8M800 Driver. scroll to right and click on "America"
This will give you your most recent driver.
Mar 26, 2011 | Gigabyte GA-K8VM800M Motherboard
Program says it cannot find any previous programs and change to win 98 then it says to put win xp back in cd then back and forth confused!!
my MSI MOTHER BOARD model no. is K8MM-ILSR(601-6741-030)
MY PROBLEMis that ......... VIA SATA RAID Driver is not working. Without this ican't install OS in my system. this driver in floppy thats why floppyis corrupt. on my floppy writen like that ......... G72-VASA040 VIASATA RAID Driver For VT6420/8237. I Want this software. my mail id [email protected]
i have msi mother board,amd athlon 64 bit processor,sata hdd 120GB,
May 04, 2009 | AOpen Computers & Internet
I format my pc driver cd lossed so i need driver
http://www.viaarena.com/default.aspx?PageID=2
You will most likely want All-in-One Driver (older is 4-in1, also called VIA Hyperion)
Mar 14, 2009 | Drive Computers & Internet
Pc wont load re-boot cd starts to load then flashs to blue screen
it is a hardware problem.if a blue screen appears on the screen while it is restarted, then try troubleshooting on the code mentioned it.
if no blue screen is seen, then the problem is with the motherboard id SMPS.you might have to replace any one of them.
Jan 04, 2009 | Acer Aspire M1640 Refurbished Intel...
Mother board not supporting sound driver.
let me know whats ur computer model  or ur motherboard model is so i can send u the right drivers.
Oct 08, 2008 | Intel D945GCL Motherboard
D101GGC MOTHER BOARD AUDIO DRIVER
http://driverbyte.com/ntel-desktop-board-d101ggc-sound-and-agp-driver-wi_freedownload/
Try the above site contains about 5 different sound drivers for d101ggc motherboard
Aug 05, 2008 | Computers & Internet
Unable to load audio driver for asus mother board pl5pl-cm
First, make sure the onboard audio is enabled in the BIOS. Then make sure it's listed in Device Manager, then download the latest driver from the Asus website.
Aug 03, 2008 | Computers & Internet
Firmware upgrade failed
Have you tried the following - right click my computer>properties>hardware>device manager>right click on your burner drive>properties>driver>roll back driver Hope it works out, let us know ;]
May 27, 2006 | LG GCE 8525B CD-RW Burner
Computers & Internet Logo
121 people viewed this question
Ekse
Marvin
Marvin
